Troyer E Fans
Troyer E Fans
Hi guys, i am going to be installing troyer e fans on my 02 F150 5.4 this weekend. All though the directions look very good I was just wondering if there is any tricks or shortcuts along the way that people have found. Can't wait to have them installed.
bigtruck311
can you be more specific on the 105 nylon fasteners. The web site you linked to is apparently for sale so found nothing there. E - Fans are going on my truck for the next mod, concered with not poking holes in my rad. coil over the long haul. Thanks!
E Fans Installed
Well I finally installed my troyer fans. If I could make any recomendations it would be this. Take off your rad it will be a lot easier. Also have the tool to hold the waterpump pulley when taking off your stock fan. That was a piece of cake once I got the right tool. It is pretty cold here right now so it is hard to get my truck to heat up. The one controller I have on the lowest setting possible and the second I got adjusted just little turn past. I will probably re set my controllers again when I get some warmer weather. But for now i need a rest cause it probably took me 9hrs only because I was trying different ways to get that dam fan off. Also taking my time puttin the rods through the rad. First drive it seemed like i could notice a bit more power by the seat of my pants, and thats great considering that with these heavy trucks. The revs also seem to come up a lot faster. All and all I'm happy. Just want to make sure i got the controllers set where they should be.
I'm in the same boat. Not really warmed up enough to really adjust my controllers. I also could tell a little more power...but it's been 1 week I can't tell anymore....NEED MORE
I spent alot of time on mine too. But mine was wiring. I did the whole solder and splice routine. My buddy lended me the fan tools...but since I had never removed a clucth fan I was clueless. I figure out how to use the tools correctly after I got the fan off.
I put my shift kit in this weekend, so that's my new toy.
Originally Posted by desparado
Originally Posted by bigtruck311
i knew i typed something wrong thank
Darn nice looking Lightning for an ''Old Man" there Desparado. You have me by three. Like I tell the Grand Kids. I'm old, not dead. By the way I had a Fal - Coon also, 260, fire engine red, black rag top. Wish I had it today.
Thanks Guys
Fan Installation
Definitely remove the radiator to do the install. Also go with the nylon straps it will save you radiator work later on. After having to replace my radiator I went with the nylon straps. I found them at my local parts shop. They are advertised for use in adding a transmission cooler to existing applications
