Fog Lights to Use
I have a 1997 F150 that came with no fog lights in the lower front bumper. Does anyone have a recommnedation on the ones to use? Are there after market lights that will fit into the opening on the bumper. Is there a way to tie the high beams into the fog lights so they come on at the same time? Thanks for your help!
You can buy the stock factory one at your Ford Dealer, about $210.00 for all the stuff to put in. Plus you can wire to use brites w /fogs too. Check out the Tech. Articles in on the home page of F150 online. I hope this helps! Your Friend, Lariat 1
Red/Silver LARIAT, SC,Flareside 4x4 ORP,Tow Pack.,A.R.E Fg. Bedcover,3.55LS,4.6L,Auto,Spiltfire Platinum 3 Sparkplugs,K&N Airfilter W/Mod.Factory Airbox,Custom Dual Exhaust W/20`` Chrome Tips,AVS Window Shades & Door Sills & Tail Lite Slots,GTS Carbon Fiber Headlite Covers,FORD 2-Piece Bra, Tinted Windows, Pendaliner Tailgate(Inner)Cover,Ford Security System W/Motion Alarm, Foglites Works W/Brites On, FORD #1 TRUCK Under Glass On Front Bumper,A/TS Goodyear Tires,Perfomance Fiction Carbon Metallic Disc Brake Pads, Owens Fg. Step Boards,55 Watt (Replacement) Backup Lites,Pilot 55 Watt Back up Lites On Hitch Under Truck. This is LARIAT 1... IN The Great State Of Indianahttp://hometown.aol.com/terrylariat1...page/auto.html
I have a 2wd 97 f-150. I also wanted the fog lights in the bumper, so I got a factory 4wd bumper and then put the factory fog lights in it. I then just installed a switch on my dash for the fog lights. With this set up, the fog lights can work with high beams also. The only problem that I ran into was blown fuses the first few days. Then I installed a heavy duty wiring set up from NAPA for high power lights.
1997 F-150 Blue 2wd flareside hard tonneau speed grille and bumper insert blue headlights 4wd bumper w/ fog lights
Hi,I live in the Philippines. I ordered a Lauriat 4 x 4 lower valance and the original foglights from the local Ford dealer. The kit includes all wiring, brackets, foglamps, and factory switch. The Ford technicians installed everything while I sat in the lounge drinking coffee. Very good work. It really looks factory installed. Cost a lot though, $625 worth of local currency. But it's worth it. No regrets. But I know they don't have the Superbright bulbs for the foglamps. Its model #9145.
Danny,
The online store here at F150online does have them for the fog lights. Or at least did last time I checked.
97 F-150 SC Lariat, Styleside, White over Gold, 4.6L (Windsor), Automatic, 3.55 rear end, electronic 4X4, w/ every option of Lariat and ORP packages except the 17" wheels (I even got the OR decals now!), MOD's so far: K&N air box mod, Gibson Super Truck, clear Bugflector II, Leer TSC 600 hard cover, Bridgestone Dueler OWL ATP 265/75 R-16's, TrailMaster Invader N7 shocks, Smittybilt step bars, Ford moulded mud guards, "White-white" head lamps, Cloud Rider Design's SS Grill and bumper opening "Summer Grill's", Bosch platinum + 4's.
Possum and others -
You guys must have a lot more money than I do to spend on fog lights - replacing the bumper and all. I took the cheap way out but I must say I like the look and the lights work really well. The beam pattern brightens the road out in front of my truck very well. In fact, I'd say I have a bit more control over the aiming of the lights and therefore the pattern. I live up a winding canyon road and this setup allows me to see not only what's on the road but what's off to the sides as well. We have many deer that like to run across the road unexpectedly. Here's a photo.
The process was simple. I lined up where I wanted the lights to be, cut an opening in the air dam, and mounted the lights to the bottom of the bumper. Be advised that there are two large frame members behind the air dam. I almost cut the dam without looking behind it first. The first spot I picked would have been directly in front of the frame members and I would never have been able to mount the lights. The lights I bought are made by Bosch and they have 100 watt bulbs that put out plenty of light.
Oh yeah! I have to tell you that my total cost for these lights was just under $100.00
This is just another way of doing it.
Black '97, SC with 4.6, 3.55 gears, automatic, 2-4 Belltech drop kit, SnugTop fiberglass lid, 3 chamber Flowmaster muffler, billet bumper grill, fog lights, American Racing 17x8 wheels with 275-60 Goodyear Eagle GT II tires.
[This message has been edited by Mr.Wizard (edited 12-11-1999).]
I was thinking of mounting some fog lamps behind the grill. I have an xlt 4x4 w/honeycomb grill. The truck already has fog lamps but want more. If you look behind the grill you will see a bar. That is where I was going to put some white pencil beams 4 I think two on each side of emblem. I think it would be different.
Merry Christmas, Akula
hey puddin' i did the same thing when i got in alittle fender bender the body shop found me some used factory bumper lights!!!
note:when i asked how much the black inserts were for the light openings they said the driver side was $7.00and the passenger was$14.00 they said ford makes alot of money by charging more for passenger side parts bcause that side gets hit alot more!!! customer service at its best!!!!!
pacific green 97 f150 4.6l..reg cab flareside ,ROUSH suspention down 3 fr and3.5rear,snug lid,carpeted bed, painted tailight accents,4x4 grill &bumper,k&n,chip,ram air kit,valvoline synthetic,accel super stock wires,platinum plus4 plugs,flow master muff,blue halogen bulbs,killer stereo, speed-glo dash,carbon fiber gauge accent,..."#6 sticker!!!!"
Steve g
The grill I have is made by Stull and its the polished model. They also have a model that has a brushed finish.
Its a tight fit and you'll say a few choice words while installing it.
I'm thinking about puting some fog lights on my truck. There are 4 square onpenings on the lower valance that is where I plan on mounting them on the 2 outside ones if I can find a way to mount them there.
2000 F150 XLT Reg. cab
4.6 Triton Engine
4x2 3.55 rear end gear
sliding rear window
automatic keyless entry
white styleside short box
4.6 Triton Engine
sliding rear window
Hey hmustang did u ever install your fog lights in those two outer openings on the bumper?? I was just wondering because i was thinking of doing the same thing. Ford dealership said they could put foglights with their kit but it would cost $300
2000 F-150 Island blue just have gotten it still haven't put the goodies on yet.
Mattcd no I haven't gotten around to it yet I might wait till spring before I do it because its either been raining or cold outside the last couple of weeks when I was off work to do any kind of work on my truck.
