Toolboxes
I have a Weather Guard Chest Box. Originally the local shop here ordered a 60", but due to the indention in front of the wheel well i had to go with the 55". The top of it sits flush with the top of the bed rail and is weather proof not water proof. It cost me about 300.00.
If you want to see a picture of it e-mail me at layugwr@fnbnet.net ------------------
98 F-150 SC XLT 4.6, Westin nerf bars, deflector shield II, Vent Visors, 55" chest box, Kenwood stereo, more in the near future
[This message has been edited by The Boss (edited 08-31-1999).]
I'm thinking about saving the 2 grand on a supercab and just getting a toolbox for lockable, weatherproof storage space. Any suggestions on what brands are best? Also, what's the best way to mount them? I think I prefer the style that fits completely in the bed, not over the rails. I saw a sharp looking Penda plastic model for about $280. I've seen Rubbermaids for pretty good prices.
Thanks!
Thanks!
I have a Delta toolbox I paid $100.00 for used. (about 229.00 or so at Lowes)
Never had any water problems.
Over the rail is better IMHO because it lets you still load plywood.
I once had a plastic box and gave it away cause I hated how cheap it was made.
Aluminum the only way to go !!!
Use a mounting kit instead of drilling holes in your truck.
99 XLT 5.4L reg cab
4x2 120" Wheelbase
4 wheel disc brakes/ABS
5 star larait style wheels
Toreador Red/Silver
3.55 gears 255/70/16 OWL
Delta toolbox
Eclipse 5340 cd player
Memphis ARCS50 component speakers w/tweeters mounted in doors(excellent sound)
Sherwood amp
2 6.5" Bazooka tubes
Lowering shackles?
99 XLT 5.4L reg cab
4x2 120" Wheelbase
Toreador Red/Silver
Delta toolbox
Sherwood amp
Lowering shackles?
I had a plastic on the rail toolbox for the past 7 years. If you are going to install a toolbox spring for the extra money to get a metal one. After a couple of summers a plastic on the rail toolbox will bow in the middle and start to look crappy. Alluminum boxes are not that much more money than a plastic one. I have an aluminum on the rail box and it cost me $150 new at an agriculture store here in Texas.
1998 F150 XLT, extended cab 3 door, towing package, 4.6L V8, 3.55 LS,Lund deflector, K&N Air Filter, Diamond Plate Toolbox, Whistler Radar Dectector, Uniden Police Scanner, 29WX-ST Cobra CB Radio Lot's of mods to come.
J-C you can contact them at 1-800-456-7865. The model number of the chest box i have is 654-6 All Purpose Chest.
Bear, I'd stay away from plastic. Most I've seen look cheap. I got a aluminum in the bed box from Sam's Wholesale for $165. I don't remember the brand name but I've seen the same box with several different names for $250 to $350. It has a single lid which is offset to rear of the truck (so you can open with out hitting rear window). I got around the plywood problem by making mounting bracket which bolt in where front tie down brackets were and stabilized the box by putting legs on the corners near the tailgate. The box is about 5 inches off the floor and sits about 5 inches above the rails. It looks good, is solid and best of all I didn't have to drill any holes in the truck. If you decide to do this let me know and I'll describe the brackets.
98 Nascar Edition, Superchip, K&N with airbox mod., Flowmaster 70 series, bedliner, in bed tool box, Profile bug deflector and window vents, Class III receiver hitch.
I looked at most manufautrers when looking for an aluminum tool box. There is quite a price difference. But I found that the quality of construction of the Better Built boxes that Wal-mart sells was as good if not better than the more expensive boxes. And, it was only $170. The lid was supported with two sperate pieces of angle versues only retangular support like the Delta. Also, it had a lift spring (proper name?) at both corners in lieu of one in the middle.
When I was looking price wasn't a real big concern, but I just couldn't see spending the extra money.
If you look under the bed rails, there are slots already there that the factory rail covers enter into. Though I did have to drill through the plastic, I didn't make any new holes in the sheetmetal.
'97 F-150, 2WD, 8'bed, 4.2L,5-spd, 3.55 axle, Pendaliner, D. plate toolbox & mud flaps, K&N filter, 3" air box mod,slotted taillight covers, Ventvisors, bug deflector, Westin nerf bars, champion truck plugs, towing pkg, 2000# helper springs, Whelen Responder 2 light bar, 100Watt Street Thunder Siren and speaker, headlight flasher, Rancho RS5000 shocks
Lowe's Home Improvement Center carries the Delta brand toolboxes. I purchsed the aluminum "deep" over-the-rail box. The lid opens towards the rear. It is lockable. It can be easily opened from either side while standing outside the truck. It is deep enough for full grocery bags. It'll also hold small suitcases, a bag of golf clubs, or many other items that you'd like to keep out of the rain! Even though the box is deep, it still has about 8-inches usable space below it so you can still carry plywood and other material without having to remove it. I paid around $200 for the box. Looks great and is very practical.
1998 F-150 Super Cab XLT, 4x4, 139" WB, StyleSide, 5.4L EFI V8 Engine, E40D Automatic,
Dark Toreador Red Clearcoat, Med Graphite Cloth Captain's Chairs, P255/70R-16 OWL AT Tires,
3.55 Ratio Limited Slip Axle, Cab Steps, Trailer Tow Package, Power Color-Keyed Mirrors,
Fog Lights, Cast Aluminum Wheels, 6-Disc CD Changer. Aftermarket: Penda Bed Liner, Keyless
Entry, Delta Deep Aluminum Toolbox, Hellwig Rear Anti-Sway Bar, Gibson Swept Side Stainless
Steel Cat-Back Exhaust, K&N Filtercharger, Custom CB and Amateur Radio Installation.
See me and my truck at http://bluecrab.richmond.edu/crab-1.htm
Bear,
The nicest truck box I have seen was a Pro-Tech. It was a beautiful piece of work, welds were very, very nice! I have seen some other truck boxes that were not nearly as neat (welders in training?). It was spendy, around $550 dollars, but like they saying goes...you get what you pay for!
2000 F-150 4x4 SuperCab XLT, 5.4 liter Triton V8 - Windsor, 4R70W automatic, Sterling 9.75" w/3.55 limited slip, towing package, sliding rear window, CD, keyless entry, Amazon Green / Silver.
77 Bronco, 64 Falcon
SDDL-UP
Where'd you see that box (Pro-Tech)? It would make a good stocking-stuffer, and a pretty big sock it'd be, for me. A lot of guys around here have their truck boxes painted to match their truck too, it looks sharp although it makes an already spendy mod even spendier, and I have 'issues' about how yuppified that would make my truck look. Thanks, bro –
R
2000 F-150 Lariat SB Supercab 4x4 Off-Road pkg, Tow Pkg. 5.4L, Bright Red over Silver, Med. Graphite Guts, Rear Slider.
R
Reavis,
Sorry it's taken so long to get back to this. I saw the ProTech at my local Quality Supply store, I don't know is this chain is nationwide. ProTech has manufacturing facilities in Nashville and Vancouver (USA).
[This message has been edited by SDDL-UP (edited 12-30-1999).]
