Airaid FIPK/Hypertech Stalling Problem?
Hi All,
I was driving to work this morning and started having some problems with
my truck...
Two weekends ago, I installed an Airaid FIPK on my '97 5.4, the truck
also has a Hypertech chip and Gibson cat-back. The kit I was shipped
had no air filter, so we created a makeshift filter from my other K&N
and a rubber piece that was removed from the truck to make way for the
FIPK. The negative cable on the battery was disconnected the entire
time until install was complete. The truck has run flawlessly until...
Last night, I received the correct filter, so I disconnected the
negative cable of the battery, removed the old filter and replaced it
with the correct one. I replaced the battery cable and went to sleep.
This morning, I let the truck warm up for about five minutes then left
for work. Half a mile down the road, it stalled. I re-fired it, it
stalled. I tried later tried revving the motor, it would peak at 2000
rpm's, then stalled. After 20 minutes of this, I gave up and am now
home typing this message, figuring out how I am going to get to work.
Any advice or suggestions? Has the Hypertech chip not realized the
addition of more air and will just take time to reset itself? Should I
disconnect the battery cable again? Please, I need to get to work! :-)
Steve a.k.a. Listmaster
F-150 Online https://www.f150online.com
my truck...
Hey Steve, sounds like a fuel supply problem to me, check your fuel filter. Did any of the idiot lights come on? If not, it probably isn't the computer. The Airaid filter is smaller than the stock K&N and there really shouldn't be any difference in air supply or flow. Could also be a batch of bad gas.
98 Nascar Edition, Superchip, Airaid, Flowmaster 70 series, bedliner, in bed tool box, Profile bug deflector and window vents, Class III receiver hitch.
Further info...
The Check Engine light did come on.
I am actually in the middle of a tank of 93 octane...which has worked fine so far.
It is the coldest morning to date since I installed the Airaid, but the truck lives in a garage overnight...
Steve
Steve
Steve,
I have a K&N kit, This Monday I put in a Hypertech chip. I have'nt had any problems yet...
Maybe try disconnecting the neg and check all the connections on your Airaid kit, if that doesnt help try removing you chip for now and then try start/running it, if that doesnt help it most likely something eles, gas supply or something...Good luck!
Red,1997 XLT 2WD, 4.6L V8, Auto
Stepside shortbed, painted to match hard tonneau cover, Ford factor bed liner, "The Best Never Rest" floor mats, Prime Designs bug & rain deflectors, 2 10" Cerwin's in custom boxes, Bel radar, K&N Gen II performance kit, Hypertech Chip
Check out my new website at: www.homestead.com/_JJK/ford.html
[This message has been edited by New2Ford (edited 12-01-1999).]
Webmaster, I installed a K&N filter setup and a performance module (Jet) and all was great until the temp. dropped to 18 degrees when Ileft for work my truck stalled at the first stop then it was hard to start,drove for about 4/10 mile & stalled again restarted and stalled about the same distance as the first time. The fourth time it stalled Iwas going 55+ and just shut off. I live 4 miles from dealer so I limped it in I left it there all day they tested and drove it all day with and without module.What they told me was when you disconnect the battery and add something new it takes about 40 drive cycles (in all temps.) for the computer to get feedback from all the sensors.He said to drive it about two days.The truck hs not stalled since I left the dealer 3 weeks ago.I hope this helps let me know.
I had a similar problem on a Buick. It turned out that when I serviced the air cleaner, I knocked the tube loose between the MAF sensor and the intake. It doesn't take much of a leak to make an engine run funny. Sounds like a leak to me.
Good Luck
[This message has been edited by Bent6 (edited 12-03-1999).]
Good Luck
Hey Steve, been busy last couple of days and haven't checked the board. Did you find the problem?????
A little time, a few removals of the ground from the battery, removal and replacement of the Hypertech chip, removal and replacement of the air filter, and it seems to be running fine now...thanks everyone for all your help!!
Steve
Steve
