Intake help
Old Oct 3, 2005 | 12:52 AM
bigplayer6907's Avatar
Intake help
2001 Screw 4x4 w/ 5.4
Im very close to gettin an intake and leaning towards the AF1. i was considering the K&N but for the same price i think ill take 6 more ponies. the only concern i have is that i keep reading about the AF1 being very loud. also does the AF1 not coming with a heat shield affect anything? would it be worth making my own heat shield or does it draw relitively cold air as is? Thanks for any help.
Old Oct 6, 2005 | 12:29 AM
jpdadeo's Avatar
I got the AF1 and I really like it. The butt dyno says extra ponies down low & up top too. It does roar at WOT though, but runs quiet under normal driving conditions. I think any CAI system is going to be louder than anything stock because the filter is exposed.
Here’s a write up about them
Airforce One Performance Intakes are designed from the ground up for absolute performance, quality and longevity. These systems use aviation grade stainless steel polished to a mirror finish that will never rust or corrode regardless of the climate the system is exposed to. Custom designed and molded Hi-Temp stabilized composite adapter boots, couplings and MAS airflow venturi adapters are used. The venturi adapter generates a high vacuum in the filter enabling the filter to draw a higher volume of air while naturally lowering the ambient incoming air temperature by several degrees, eliminating the need to enclose the filter in a box and substantially increasing horsepower. The Power Stack Filters are sized to each system and carry a lifetime warranty.
