Best Bang for my buck
Old Mar 7, 2005 | 01:53 AM
V8SilverSTX's Avatar
Ok im looking for something to give me more acceleration power.I already have the Superchip tuner and electric fans and a exaust system. Here are the options.
Intake
Underdrive pulleys
or an ignition system
Which one should I get next.
Old Mar 7, 2005 | 08:22 AM
jpdadeo's Avatar
A good intake system would compliment your exhaust with increased airflow in and out, and of course, under-drive pulleys will free up existing hp (12hp to 15hp) that is available right from idle. Every little bit of hp counts!
Old Mar 7, 2005 | 05:30 PM
98F150XLT4.6L's Avatar
I would go with the intake. It seems that it would be easier to install than pulleys and produce the same amount of power (15 hp). I just recently installed an Air Force 1 Intake and I love it. That is THE intake to get. Just my $0.02
Old Mar 11, 2005 | 01:33 AM
Middleton28's Avatar
The first product I put on my truck was an air intake and I could tell a huge difference in the bottom end. The air intake alone did wonders to wake up my truck.
Old Mar 11, 2005 | 05:21 AM
Faster150's Avatar
electric fans exhaust or under drive pulleys are best bang for buck
Old Mar 11, 2005 | 10:49 AM
max mitchell's Avatar
He said electric fans and an exhaust were already installed. He asked for ONE selection from his 3 choices.
V8SilverSTX- Skip the ignition. If you're going in order of performance per dollar, next in line would be the full intake. I do highly recommend the underdrive pulleys, next down the list.
Old Mar 18, 2005 | 02:26 PM
J-150's Avatar
go gears next.
Old Mar 18, 2005 | 06:19 PM
Jordan not Mike's Avatar
Originally posted by J-150
go gears next.
Depending on the gears you are starting with, a shorter rear-end may give you more oomph than any of the aforementioned mods.
For example, if you currently have 3.31, then going to 4.10s will give you a huge increase.
But if you have 3.73, then look elsewhere.
Old Mar 19, 2005 | 01:47 AM
05FRF150's Avatar
lookin for acceleration...get a supercharger 'an blow the doors off of anything.....
sure its a few bucks, but the power is always there...
