Electronic Lockers
Electronic Lockers
Does anyone know of a good place to get a good e-locker? What are some brands poeple have been having good luck with?
After one winter with this open diff. I realized I really need a locker-not to mention the embarassment of leaving one tire mark after a burn out
Are these things hard to install or should some one who really knows what they are doing put it in?
what type of rear axle have you got? anser that and i can give you a huge list if it is a 8.8 or 9 inch if it is a 9.75 like i have you are sol on a locker or e locker auburn makes the best ls for the 9.75, if you have never tore apart a diff before i recomend finding a freind who has to help you if you are macanicly inclined i wouls say go for it but follow the derections to the t, it takes me about an hour or 2 to do a diff change but i have done it a few times, you need a bearing press to put in the new diff, let me know what axle you got and i can give you more info i hope this helps
first off what rear axle you got? if it is 8.8 or 9 inch i know of alot of people who make lockers and e lockers if it is a 9.75 like i got you are sol, auburn gear makes the best ls for the 9.75 in my opinion, if you have never torn apart a axle before a recomend you find a freind who has or read the instructions very carefully, you will also need a bearing press to put the bearings on the new diff ***. i hope this helps if you need to know more just ask i have torn apart a few axles and reaplaced diffs ring and pinoins too if you got questions i probably got an anwser hope it helps
Hey thanks for the help. Im not positive but I think I have the 8.8 rear end. Is there any where I can look. On a tag on the diff. I found '8l8' stamped on it so im am kind of thinking thats what it is. Even before i found the marking i was thinking it was a 8.8
there should be two tags one on the right one on the left the one on the right should tell you your axle size and your ring and pinoin most lickly 3.55, and recomended fluid used, if it is a 8.8 then alot of people make e lockers and auto lockers, detroit, aubern gear, eoton, do you really want an e locker or would an automatic locker be ok?
I understand that ARB could have a locker ready for the 2004 Ford F150 9.75 by the end of year if enough people show an interest.
So lets send some emails to them so they can get one in R&D.
sales@arbusa.com
ph. (888)-4ARB-USA
sales@arbusa.com
ph. (888)-4ARB-USA
hey greffed, who did you talk to at arb i talked to there guy and he said they arent even thinking about it but that was like 4 months ago, i wish they would come out with one for the 9.75
I believe it was sbisig@arbusa.com I received this info within the past 3 weeks.
i just e mailed that guy, we should post that e mail and get everyone who is enterested to e mail him so that they might speed up production if they know there is a high demand you know what i mean? thanks for the e mail for that guy by the way
bad newsUnfortunately, a locker for the Ford 9.75 isn't even on the drawing boards.
The engineers still have a few projects to finish up before they can start
on another, and even then, the next highly requested locker will start
development. My recommendation is to keep in touch with us every couple
months for any new information. If you have anymore questions, please feel
free to ask.
Best Regards,
Steven Bisig
ARB Tech
ARB-USA
sbisig@arbusa.com
ph. (206)-264-1669
ph. (888)-4ARB-USA
fax.(206)-264-1670
