News: Ford to Introduce Dual-Clutch Powershift Transmission in North America
Old Jan 21, 2009 | 01:39 PM
Rockpick's Avatar
Moderator &
FORD TO INTRODUCE FUEL-EFFICIENT DUAL-CLUTCH POWERSHIFT TRANSMISSION IN NORTH AMERICAN IN 2010
DETROIT, Jan. 21, 2009 – Ford Motor Company announced today it will introduce an advanced dual-clutch PowerShift six-speed transmission in North America in 2010 for the small-car segment.
PowerShift will deliver the fuel efficiency of a manual gearbox with the convenience and ease of a premium automatic transmission – making it a key enabling technology as Ford targets best in class or among the best fuel economy with every new vehicle it introduces in North America.
“PowerShift represents a true competitive advantage for Ford and is one of the many technologies that will help our global small car platforms set a new world standard for efficiency and drive quality,” said Barb Samardzich, vice president, Global Powertrain Engineering, who announced PowerShift’s production timing at the 2009 Automotive News World Congress. “This advanced six-speed is an improvement over today’s automatic transmissions in terms of fuel economy, while providing customers an even more fun-to-drive experience.”
Overall, Ford has committed that almost 100 percent of its transmissions will be advanced six-speed gearboxes by 2013. Six-speed transmissions already have helped vehicles such as the 2010 Ford Fusion achieve best in class fuel economy, while at the same time allowing the Ford Flex and Ford Escape to achieve unsurpassed fuel economy in their respective segments.
Ford is leveraging six-speed transmissions, advanced internal combustion engines such as EcoBoost, hybrids, full electric vehicles, vehicle weight reduction and electric power-assisted steering to improve fuel economy and reduce greenhouse gas emissions fleet-wide by 30 percent by 2020.
Automatic Comfort
Compared to traditional automatic four-speed transmissions, PowerShift can help reduce fuel consumption by up to 9 percent depending on the application.
PowerShift provides the full comfort of an automatic with a more sophisticated driving dynamic, thanks to uninterrupted torque from the dual-clutch technology, which consists essentially of two manual transmissions working in parallel, each with its own independent clutch unit. One clutch carries the uneven gears – 1, 3 and 5 – while the other the even gears – 2, 4 and 6. Subsequent gear changes are coordinated between both clutches as they engage and disengage for a seamless delivery of torque to the wheels.
In Europe, Ford currently offers a PowerShift transmission in the Ford Focus. This PowerShift uses a twin wet-clutch system to handle the higher torque levels of the 2.0-liter TDCI engine available in the Focus.
In North America, a dry-clutch derivative of Ford’s PowerShift transmission will be used for added efficiency and durability. A dry clutch transmits power and torque through manual transmission clutch facings, while most automatic transmissions utilize wet clutch plates submerged in oil. As a result, the dry-clutch PowerShift transmission does not require an oil pump or torque converter, providing superior mechanical efficiency.
“A dry clutch is a real sweet spot for lighter vehicle applications,” said Piero Aversa, manager, Ford Automatic Transmission Engineering. “PowerShift is more efficient, it saves weight, is more durable, more efficient and the unit is sealed for life, requiring no regular maintenance.”
PowerShift, unlike conventional automatic transmissions, does not need the heavier torque converter or planetary gears. In addition, the dry-clutch derivative eliminates the need for the weighty pumps, hydraulic fluids, cooling lines and external coolers that wet clutch transmissions require. As a result, the dry-clutch PowerShift transmission can weigh nearly 30 pounds less than, for example, the four-speed automatic transmission featured on today’s Ford Focus.
Differentiating PowerShift even further in terms of its customer appeal is its shift quality, launch feel and overall drive dynamic, which are all facilitated by an expert blend of Ford-exclusive electro-mechanical systems, software features, calibrations and controls. These unique driving features include:
Neutral coast down – The clutches will disengage when the brakes are applied, improving coasting downshifts and clutch robustness as well as reducing parasitic losses for increased fuel economy.
Precise clutch control in the form of a clutch slip to provide torsional damping of the engine vibration – This function improves noise, vibration and harshness (NVH) at low engine speeds and enables lower lugging limits for improved fuel economy.
Low-speed driving or creep mode with integrated brake pressure – This function simulates the low-speed control drivers are accustomed to from an automatic transmission. The amount of rolling torque in Drive and Reverse is precisely controlled, gradually building as brake pressure is released.
Hill mode or launch assist – Prevents a vehicle from rolling back on a grade by maintaining brake pressure until the engine delivers enough torque to move the vehicle up the hill, providing improved driver confidence, comfort, safety and clutch robustness.
About Ford Motor Company
Ford Motor Company, a global automotive industry leader based in Dearborn, Mich., manufactures or distributes automobiles across six continents. With about 224,000 employees and about 90 plants worldwide, the company's core and affiliated automotive brands include Ford, Lincoln, Mercury, Volvo and Mazda. The company provides financial services through Ford Motor Credit Company. For more information regarding Ford's products, please visit www.ford.com.
Old Jan 22, 2009 | 06:35 AM
Low_e_Red's Avatar
This is cool and good news for Ford.
Old Jan 23, 2009 | 04:22 PM
very interesting stuff, i will have to do some research on this
Old Jan 23, 2009 | 08:18 PM
Veteran: Army
I've driven the focus with the trans they mention above and they are actualy peppy
Old Jan 23, 2009 | 08:31 PM
Lumadar's Avatar
Can't wait for a sport edition EcoBoosted Focus with that in there...
Old Jan 25, 2009 | 04:02 PM
That would be cool... so is it clutch by wire? 3 pedal?
I seen VW has a manual transmission that is clutch by wire...
Old Jan 26, 2009 | 05:32 PM
n3up's Avatar
This sounds sort of like the ZF AStronic auto stick that was in a 2005 VanHool C2045 motorcoach that I drove a couple of summers ago.
It was a 12 speed manual with automated clutch. No clutch pedal. Just step on the accelerator and it goes....
It was a little weird getting used to, but once I got used to the fact it wouldn't "creep" like a regular auto trans, and it felt like a conventional manual when it shifted, it was pretty cool to drive.
The system was smart enough to know if you were on the flat or a hill, and it would skip gears when appropriate. On a flat start, it would usually start in 3rd then go 5th, 7th, 9,10,11,12. On a hill it would start in 1st and go through all 12.
The coach had a C13 Caterpillar, about 450 horse I think. It was performance equal to an on older 2003 C2045 that was with us that had a Detroit series 60 and Allison 6 speed conventional Auto trans.
Old Jan 29, 2009 | 07:46 PM
King James's Avatar
This sounds like Ford's version of the DSG that VW/Audi uses. Here is some more information.
http://cars.about.com/od/thingsyoune...owDSGworks.htm
