Aftermarket DVD Install ?
Old Oct 19, 2010 | 10:05 PM
Rodneys's Avatar
I have a question. I have bought a DVD player and want to install in our 04 f-150. I looked at the wiring for it and all it needs is a 4 wire hook up ( not counting the audio/video in & outs-- will not use these). It has a 12+ constant,,12+acc,,ground,,& blue wire for the dome light. Where would be the best place and what to tap into to use,,,can I tie the two hot wires together and go with 1 hot wire ,,,thanks
Old Oct 20, 2010 | 12:11 AM
Sundevil2188's Avatar
Im assuming your talking about a DVD player for head rest monitors or an overhead and not an indash, correct?
Old Oct 20, 2010 | 09:06 AM
Rodneys's Avatar
oh,,It will be the Roof overhead unit...not the factory one.
Old Oct 20, 2010 | 10:19 AM
you have to run 2 12v, one to constant and one to ignition. Otherwise the screen will always be one instead of on when the key is in the ignition and turned to run. easiest place to get those wires is your head unit
Old Oct 20, 2010 | 04:53 PM
Rodneys's Avatar
ok thanks alot
