Easy install? How
Old Apr 26, 2010 | 06:40 PM
bigguns010's Avatar
Easy install? How
How easy exactly is putting in a new dvd/gps? A double din. Anything i should know about?
Old Apr 26, 2010 | 07:13 PM
JJDH's Avatar
Isnt too bad. vss wire for gps and everything else is normal.
Old Apr 26, 2010 | 08:56 PM
Ducatimikep's Avatar
New generation navs don't even use VSS.
Completed mine 3 weeks ago.....
Old Apr 26, 2010 | 09:51 PM
JJDH's Avatar
If you use pioneer nav it DOES use vss. Connect pink wire to black / grey in wire harness.
Old Apr 27, 2010 | 10:43 AM
Sounds like Pioneer uses old technology then.
The brands that I looked at prior to purchase
all get the speed info through the GPS antenna
(Alpine, Kenwood, JVC, Clarion, Rosen).
Makes for a true plug & play install, no chasing
of unrelated audio wires.
Old Apr 27, 2010 | 11:25 AM
06xlt4x4's Avatar
You don't have to hook it up. Its only for if you lose signal going through a tunnel it can tell if your still moving. I didn't hook mine up for the 2 years I had it.
Old Apr 27, 2010 | 11:26 AM
06xlt4x4's Avatar
Install isn't too bad. Just normally has a lot of wires, just follow the instructions and keep things organized with zip ties and electrical tape for a clean install and you'll be done in no time!
Old Apr 27, 2010 | 04:34 PM
JJDH's Avatar
the vss is so the gps is accurate within 10 feet.
Old Apr 27, 2010 | 04:35 PM
JJDH's Avatar
Pioneer isnt outdated. The vss gives accuracy within 10 feet. Ask the manufacturer. Of course it works without it. It is there for a reason.
Old Apr 28, 2010 | 12:59 PM
"DNX6160 (Kenwood) acquired 13 out of 14 satellites (#19 being the one I couldn't) within 4 seconds, with the accuracy being less than 10 feet...."
CNet reviews on Kenwood
without the vss
Old Apr 28, 2010 | 06:51 PM
JJDH's Avatar
good job!
