OEM NAV and the "Terms of Agreement"
Old Apr 1, 2010 | 10:34 PM
Nemisus's Avatar
couldn't find an answer with search so here goes...
The GPS "Terms of Agreement" screen... Is this something I'm going to have to agree to every time I start my truck?
Any info will be greatly appreciated!
Cheers
Nem
Old Apr 2, 2010 | 09:19 PM
TIKT B8's Avatar
Assuming you have a facoty unit, yes you will have to agree to those terms every time and it will lock you out of most options when you drive faster than 5 mph.
If you want to use the factory nav unit without the driving restrictions, here are the instructions (from wiingnut on another board). Use at your own risk. I have done this and it works great.
1. Take vehicle outside and agree to nav instructions. The gps needs to know its position.
2. Push hard nav button (on right side of radio). Go to your address book. Pick any of one of your saved addresses. Now that address is highlighted, look to right and push soft edit button. You will now see name of saved address.
3. Clear name of saved address and type in F-DEVELOP ON
(make sure to put space between DEVELOP and ON).
4. Now look to the upper left corner and you will see the word ADDRESS. Place your finger directly under the A and hold. If you do this right, the screen should change to the map screen.
5. Now push your hard menu button (on left side of radio). Across top of radio push soft SECURITY button. You have now entered security screen. You will see nothing in the bottom right most corner of nav screen. Push your finger and hold in that position till the screen changes.
6. You now have entered a parameter screen. Locate DRIVING RESTRICTIONS release. When you push the button it should change to driving restrictions stop. Exit the screen by pushing the soft BACK button.
7. Congrats you have just programmed your factory nav radio. NOTE: Every time you turn your vehicle off, you will need to repeat steps 5 & 6.
Good luck and enjoy. If you choose to monkey around with your other parameters, do so at your own risk. I will not be responsible for your dealer service call. If you have any further questions, please pm me and I will do my best to help. This programming sequence should work for only the so called first generation navs. It will not work in the MY09, second generation. This has been used to reprogram many MY 07 and MY 08 Ford vehicles.
Old Apr 2, 2010 | 11:31 PM
Nemisus's Avatar
Thanks TIKT,
This is all very interesting stuff! I'll keep it in mind. My only concern is repeating steps 5 and 6 at turn off, seems like more bothersome than just hitting agree on start up!
I'm not too concerned about the driving restrictions as I'm pretty new at using the NAV to begin with!
Do appreciate your response!
Cheers
Nem
Old Apr 2, 2010 | 11:38 PM
greencrew's Avatar
LOL
Old Apr 7, 2010 | 09:05 PM
medic2586's Avatar
can you program other parameters such as subwoofer on/off using these steps?
Old Jul 30, 2010 | 05:21 PM
City of Champs's Avatar
i did this and did not see the choices for subwoofer or anything for Sirius, but you can change the style for ford, Lincoln, mercury, or Mazda
Old Aug 7, 2010 | 02:48 PM
sjfrontera's Avatar
will this work for the 2010?
Old Aug 9, 2010 | 05:20 PM
TIKT B8's Avatar
Thanks TIKT,
You will always have to hit the agree button regardless of what you do. The steps that I have you will allow you(or hopefully your passenger) to use the nav functions while the vehicle is in motion. Those two steps take no more than 5 seconds.
No, it will not work with a 2010.
Old Aug 12, 2010 | 08:14 AM
sjfrontera's Avatar
Any advise for the 2010????????????????
Old Aug 12, 2010 | 08:36 AM
shotgunz's Avatar
https://www.f150online.com/forums/20...-lockpick.html
