Ford Nav / Radio
Old Apr 15, 2009 | 09:33 PM
teddym's Avatar
Ford Nav / Radio
Can any one HELP! I bought an Ford Nav / Radio from cragslist the radio was working. When I installed the nav disc I had the truck ignition in ACC I put in the disc then by accident shut off the power on the screen the hour glass kept turning and said loading disc but it won't get out of the screen of loading it won't shut off in doesn't do anything I think it is locked up or something.Should I disconnect the battery over night? and see what happens? Does anyone have an idea? Thanks!
Old Apr 17, 2009 | 03:24 PM
teddym's Avatar
Problem Solved
The Problem is FIXED. Dominic and his tech.Jason are the GREATEST they figured it out and fixed the problem. NEVER put an older nav disc in than what was in previously.Meaning if you had orginally had used a 6p version DON'T put in a 2p.I know it sounds stupid but it happens. I bought a 2007 ford nav unit on Craiglist and the guy gave me a 2p disc which he had already used a 4p version he swapped the disc with a friend to give him a newer version and took the 2p version to give with the unit he was selling.The Nav unit froze up ( locked up ) could not do anything with it JUNK,but Dominic and Jason @ Automotive Resource Center, in Winchester, MA. 1 (781) 721-0092 worked it out swapped out parts from another, programed it and it works GREAT. I highly recogmended them for any mods or Accessories to install Factory or Aftermarket Products. I've seen the shop and talked with them one on one.I am soo Pleased and GREATFUL for all there help and understanding.THANK YOU!!! DOM @ ARC: two
