Bypass relay wiring
Old Mar 17, 2009 | 11:36 PM
MX81's Avatar
Bypass relay wiring
Will I have any issues doing this if I have an amp hooked up to the HU and the remote wire wired into the relay ?
Old Mar 21, 2009 | 09:27 PM
04screw22s's Avatar
Nope...... Just make sure that you hook :
1. connect "30" to the green parking brake wire from the H/U
2. connect both "86" and "87" to ground (I tied both together and used a ring terminal and screwed it to the metal behind the H/U
3. connect "85" to the remote turn-on wire from the H/U
This procedure works flawless.
Old Mar 22, 2009 | 01:40 AM
Low_e_Red's Avatar
Glad my bypass could help.
Old Mar 23, 2009 | 08:45 AM
MX81's Avatar
Thanks...worked perfect
