Installation
Old Jan 12, 2009 | 09:53 PM
POPHI's Avatar
Installation
ANYONE THERE... HAVE A 2003 Toyota Sequoia. I need to install a Pioneer Avic-f700bt nav. stereo. I want to still access my steering wheel controls and I have JBL speakers. What do I need to install my system???
Old Jan 12, 2009 | 10:40 PM
yetti96's Avatar
Um, this is a Ford F-150 forum but we have actually listed somewhere here the adapter to make factory steering controls work. Search....
Old Jan 13, 2009 | 09:53 AM
blackFX4ny's Avatar
Check avic411.com, tons of helpful stuff to read there.
Old Jan 13, 2009 | 10:21 AM
NCSU_05_FX4's Avatar
X2! What makes you think we'd know about Toyota Sequoias?
- NCSU
Old Jan 14, 2009 | 11:11 AM
Low_e_Red's Avatar
I do!
Look, since you have the JBL system either you will need a MET TY-TOY1 or its an entire rewire. The amp is under the center console, right below the tray. There are two plugs, and you must run speaker wires from the player down to the amp.
Front Left - Green+ and Blue-
Front Right - Pink and Purple
Rear Left - Black and Yellow
Rear Right - Red and White
Once you have rewired that, you may remove the amp. It makes a great spot for the XM tuner.
Then for SWC, if I remember correctly its 3 wires on an aux plug behind the radio. White, Green/Black and Brown. I think the white needs the 1k resistor, Green/Black goes direct to the Green wire on the SWIPS I believe. And the brown is grounded. (The wire colors and pin locations will be in the box.) Oh and CC has a promotion currently. Get the SWIPS installed for 99.
Oh and if you need any extra info, I have posted instructions for the rewire over at AVIC411.com under the name RPyfrom1. And then you can always email me as well.
