My Camera Doesnt Work!(DNX7100) Help!
Old Jun 3, 2008 | 11:18 PM
mgp32's Avatar
This is the second camera Im trying to hook up because the first one I thought was broke...well Im starting to think IM doing something wrong. Im using a Boyo VTL420. Hooking the red to 12V+ and black to ground. And than testing if the camera works by applying the purple reverse wire from the DNX7100 to the 12V+ which should in turn enable the monitor and show the camera display but its not working?
whats going on? I have a 12V tester and 12V tests good. I also have the yellow RCA plugged into the reverse Female RCA from the 7100.
Any help would be appreciated!Im going nuts...I want this camera installed..
Old Jun 4, 2008 | 02:20 AM
Low_e_Red's Avatar
Ive tried one Kenwood on the Rev wire (Black/Pink in the DKP and I think I remember it being the wrong polarity for the Kenwood. Either a switch or a relay would work here... But it has been over a yr and I dont fully remember)
Old Jun 4, 2008 | 04:00 PM
05supercrew's Avatar
I have the same camera, I didnt hook mine up but remembered looking at the wires. There is a acc. 12v wire and a ground wire plus there is a wire that gets tapped into your reverse lights and the rca cable. 4 wires all together.
Old Jun 4, 2008 | 06:25 PM
shanecaseber's Avatar
yah thats right and you tap the line from the head unit to the reverse light
Old Jun 4, 2008 | 10:12 PM
mgp32's Avatar
I figured it out myslef...had to go into AV interface and enable reverse camera interuption
