Does anyone have the Alpine PKG-RSE2
http://www.alpine-usa.com/US-en/prod...model=PKG-RSE2
http://www.crutchfield.com/App/Produ...2&i=500PKGRSE2
Does anyone have this overhead dvd/monitor in their truck? I have a rail system in my truck and I was wondering if anyone else has it. If so what do you think about it? and will it work with the rail system
The rail system will not work as it will take up the space the PKG needs. The PKG is just like any other OMV as far as mounting is concerned.
If i get one it will be that unit. NO QUESTION!
Your help is needed fella's. I would like to know if you thnk this will work in my truck. If so, what wires can I use for power, constant, ground. Where will the bracket that holds it up get installed at.
Do you guys think that I can install it over the rail system somehow.
Your 12v and everything may already be there at the back of the light... You could always screw the ground into some body metal....
Might look like an antenna...
were there is a will there is a way, im sure something could be fabricated to make it work with the rail system.....
Of course if I wanted a 72" TV in my backwindow I could put one there....
