Custom overhead monitor...long write up and Lots of pics!
Subscribe
May 30, 2007 | 11:16 PM
Quote: Is there something to hold still it when it is in the open position? I was just wondering if it will bounce around when you go over bumps.
Looks great, by the way!
Thanks... and from above
Quote: It fit perfectly back into place and with the added tension of the wire it has a little more firmness to it when you open it as opposed to teh regular sunglass holder.
the OE sunglass holder has a "stop" notch on the swivel hinge to keep if from bouncing. with the added wire at the top and the weight of the actual monitor it provides it with a firm position. i can actually only open it partially and it stays that way. The wire keeps it fully opened and from swinging/swaying. it feels firmer and tighter thru the range of motion of the hinge because of this.
i drove it the first day open over all kinds of terrain and it kept still.
It works as well as or better then you would expect an OEM unit to function.
Reply 0
May 31, 2007 | 03:09 AM
wow great work!! everything look really good.
Reply 0
Jun 2, 2007 | 03:08 PM
Excellent form and function
Reply 0
Feb 19, 2012 | 11:38 PM
This may be my next project. I'm not brave enough to learn how to do the headrests for the first time on my screw, and I'm not a real big fan of any of the drop down lcd options either. I think this looks badass and provides the perfect viewing angle for the back seat.
Reply 0
Subscribe
