Indash video
Old Oct 24, 2006 | 04:43 PM
jmt0645's Avatar
Exclamation Indash video
Is it true that all I have to do is ground the e-brake wire to be able to watch DVD's while moving.
Old Oct 24, 2006 | 11:39 PM
polo2005's Avatar
it only works in certain models of equipment, but there are several ways of bypassing that
Old Oct 25, 2006 | 01:25 PM
jmt0645's Avatar
Talking Pioneer
This is what I'm thinking about.http://www.crutchfield.com/S-4EEScTM...130AVHP680#Tab
Owners manaul/instructions are on the upper right hand, just click the link.
Old Oct 25, 2006 | 04:30 PM
polo2005's Avatar
yeah, but gorunding the brake wire only works some times. Some people have hooked it up to the headlight switch and just turn the lights on and off real fast and it bypasses it. Im not sure how they did it but do a search or ask and they help you with that.
Old Oct 25, 2006 | 06:28 PM
bushtree's Avatar
it depends what model you are using.. some can be grounded and they work others require a more complex bypass series or steps.
Old Oct 26, 2006 | 11:04 AM
snowboarder7710's Avatar
that one will most likely need to see a ground, no ground, ground. so you will need a toggle switch to bypass it. the manual will tell you to apply the e brake, release the e brake, and re-engage it.
Old Oct 27, 2006 | 03:42 AM
hawaiianblood44's Avatar
thats how i bypass mine on-off-on with 1sec between but sometime i can get lucky and flip it really fast and it works. hey it only took me about 3 hrs, 6 butt connectors, and million mosquito bits to figure how to bypass my HU.
Blood,
Old Nov 7, 2006 | 06:11 PM
recon_sct's Avatar
Registered User
jmt0645, hey I just installed the unit you are talking about into my truck. The bypass to watch videos when you are moving depends on when your unit was built. The ealier units require you to hook everything up as you would normally then when you start your truck and the unit is booting you would turn your headlights on and off at a certain time. You could do that everytime or you could buy a bypass circuit that would make the unit think that you turned your lights on, that why you wouldnt have to remember to do it everytime or if you have HID's installed you wouldnt run the risk of burning them up flashing them all the time. The newer units (like mine) require you to ground the parking brake wire and another pin on the back of the unit, it's not that hard but it is frustrating fiddling with the connector to get that on grounded. anyway go here for more bypass info for the Z1, it will give you a lot of info and this is what I follwed when getting mine to work.
Old Nov 7, 2006 | 07:43 PM
jmt0645's Avatar
Lightbulb
Recon sct, were did you put the speed sense wire?
Old Nov 7, 2006 | 09:47 PM
Bravosix1's Avatar
we have an 05 and used the gray w/white wire found at pin #14 on the original wire harness. Our stock radio had speed adjust on it.. Just tapped that wire and our Z-1 worked great.
Old Nov 8, 2006 | 03:11 AM
recon_sct's Avatar
Registered User
I followed this when putting mine in and everything works great!
http://www.fordf150.net/forums/viewtopic.php?t=31939
hope that helps you out some.
Old Nov 8, 2006 | 12:01 PM
akheloce's Avatar
If anyone really cares, a guy up here in alaska got charged with second degree murder for getting into an accident while having his in-dash dvd player on (which he modified to let work while moving). He said that it was for his passenger to watch while he drove, but the DA didnt believe him.
edit: here's the story and pic of F-150:
http://www.anchoragepress.com/newarc...vol12ed44.html
Old Nov 8, 2006 | 01:51 PM
midnightwhite's Avatar
i remember hearing about this, and have kept it in mind as I look for a dvd system.
BTW akheloce, are you a year rounder? My bro-in-law runs a fishing charter out of the spit. Was up there last summer, very nice town.
Old Nov 8, 2006 | 02:17 PM
akheloce's Avatar
Yeah, I technically live there year round, but my job has been making me stay in anchorage more and more... I keep an apartment in Anchorage, in addition to my house in Homer which I've only gotten to on the weekends recently.
I may or may not know or have heard of your bro-in-law, since I think the number of charters has tripled in the 10 years I've lived there... lots of new faces.
Old Nov 8, 2006 | 05:38 PM
jmt0645's Avatar
Do you think grounding the brake wire on this TV tuner will work also?http://www.crutchfield.com/S-znjLape...130P5700TV#Tab
