Navigation double din
Old Jul 30, 2005 | 05:52 PM
chadman51's Avatar
looking for a navagation unit that is double din with some kind of Security
does any body know of any?
i seen that eclipse has ESN Security but there web site says nothing about it
(ie what it is or does)
thanks for the help
Old Jul 31, 2005 | 09:42 PM
chadman51's Avatar
anybody???????????????????????
Old Aug 1, 2005 | 08:38 AM
dconder's Avatar
Eclipse's ESN security feature allows you to set a code, using a certain CD play will lock and unlock the code. When asked for the code, you put this CD in and it reads it and unlocks or locks the unit. If the unit is locked and you do not use the proper unlock CD, then the unit will not operate. The downside is if something happens you loose the CD or it gets broken, then you are looking at having to send it in to Eclipse to get it unlocked. If your unit is stolen while being locked and you have registered your unit with Eclipse, they will replace the unit for, I think, the first year. It must be purchased at an authorized dealer to be eligible.
I hope that helps some. I have had 5 or 6 Eclipse units but have never used the ESN feature. I have always been worried about something happening to the Key CD. Good luck with it.
Old Aug 1, 2005 | 06:35 PM
kaboy65's Avatar
the double din kenwood has a screen that you enter a password on. If the power to the deck is lost it automaticly locks the unit up and you have to reenter your password.
Old Aug 1, 2005 | 09:12 PM
chadman51's Avatar
thanks for the help guys
