vehicle speed sensor wire hook up? navigation question
Old Jul 21, 2005 | 11:48 PM
cjhall222's Avatar
I am wondering if anyone knows which harness the gray/black wire is on the f150s wiring harness is the one i need to hook up to on 04 f150 5.4L for the vehicle speed sensor input, there is a gray/black strip wire on the middle harness of the three on the computer behind battery is this correct.
and can i just ground the parking brake wire to get screen to play while moving on avic 90dvd -navigation unit. Thank you
Old Jul 22, 2005 | 09:51 AM
grayvader's Avatar
Did you look on the HU harness? I thought it went to the factory radio harness for the speed-volume feature.
Old Jul 22, 2005 | 08:43 PM
no1papajohn's Avatar
VSS wire
I found mine in the passanger side kick panel. Was very easy to get too.
F150 2003 Supercrew
Old Jul 22, 2005 | 10:23 PM
cjhall222's Avatar
looks like factory radio harness has speed wire for hwy volume control feature on audiophile system
Old Aug 9, 2005 | 02:56 PM
Thumper24's Avatar
will be installing my D1 this weekend in my 05 screw...
i looked and looked through this forum and the info didn't exactly jump out and grab me, so....
just so I got this straight --> in the factory radio harness, there is a gray/black wire which is the lead for the speed control volume. this wire is adequate to hook the D1's speed sensor lead up to? Correct? If not, then which color wire is it on the radio harness that the speed sensor is run to?
Old Aug 9, 2005 | 11:25 PM
cjhall222's Avatar
The grey/black wire will work for you
Old Aug 10, 2005 | 10:18 PM
Thumper24's Avatar
Thanks! Will do the install this weekend. I plan to document it and post for future do-it-yourselfers.
Old Sep 6, 2005 | 08:54 PM
05f150virgin's Avatar
Thanks - Grey Black worked great although not much wire to work with
Old Jun 4, 2011 | 12:39 PM
F150-15851's Avatar
is it the small Grey with black stripe in pin #14?? lines up with the pink phone mute wire on Schoche kit.
Old Jul 7, 2011 | 01:32 AM
Low_e_Red's Avatar
Yes.
