kenwood nav/dvd owners
Old Feb 27, 2005 | 01:16 AM
r6racer's Avatar
Have any of you had any problems with the turn by turn voice guidance? If so, did you fix it or not? If you fixed it, what was the problem? I can't get mine to work. When I input a destination and start guidance, the voice comes on and says "please proceed to the highlighted route and guidance will begin" or something to that effect. But the voice guidance does not begin. The route is there and my location changes but no dam voice When I touch the speaker icon it says "please refer to the map" Any answers would help.
Mitch
Old Mar 15, 2005 | 08:14 PM
vickerto's Avatar
You need to connect the speed sendor wire. It is the grey/black wire on the wiring harness. Search the forums for 'speed sensor wire' for more info.
Tom
Old Mar 15, 2005 | 08:33 PM
r6racer's Avatar
thanks
I know what color it is but I cant find it or a good place to tap into.
Old Mar 16, 2005 | 07:12 PM
jlcotney's Avatar
If you had the speed sensitive volume on the stock radio there is a vss wire in the harness connecting to the radio. I used this wire in my 2000 f150 for the dv4100 system and it works perfectly. I'll see if I can dig up the correct wire for you.
Old Mar 19, 2005 | 08:57 AM
jlcotney's Avatar
I believe its a Gray/Black wire in the factory harness. I don't know how many plugs your orignial radio had. My truck had a 16 pin and a 20 pin. In the 20 pin harness, thats used for a factory cd changer and other random things, the vss wire can be found. If you have an extra connector that you didn't connect when installing th aftermarket system I would check it. I hope this helps.
Old Mar 20, 2005 | 03:43 AM
r6racer's Avatar
thanks
its been awhile since i put it in so ill have to look at it again. i do know that there was only 1 wire harness not 2. i think there was a red/? wire not used. thanks for the info though.
Old Mar 30, 2005 | 05:15 PM
r6racer's Avatar
got it
I talked to an installer by my house and he said they pull the gauges out and tap into the back, so that is what i did. The grey/black wire was right there. couldn't have benn easier. Now its like i have an all new stereo again. The voice guidance works great. Thanks for the advise on the colors guys. Mitch
Old Mar 30, 2005 | 07:37 PM
jlcotney's Avatar
Glad to hear that worked out. The voice guidance is great. I like all of the different accents and languages you can get the unit to use. My roommate was amazed at the things this unit can do. Anyway, hope you enjoy the new features.
