06 mark lt problems?
I have a 06 mark lt, it seems to make a ticking or longing when it idles, when its cold out and the engine is warmed up, I can't hear it from the cab, it has no check engine lights or anything like that, can hear it only at idle once I step on the gas it goes away, it has high oil pressure and the truck gets up and goes when u step on the gas, should I be worried? It make the noise when the outside temp is around zero and the motor has been running for a while, its pretty noticable when its running in the garage but Idk maybe I'm just paranoid? Let me know what you think
Well, it could be an exhaust manifold leak or a lifter or the oil filter might have a stuck anti-drainback valve inside.....
Originally Posted by tobyjss
(Post 4950689)
Both my exhaust manifolds rusted out, sounds similar to your issue.
Although could be a slew of different oiling issues as well |
