Should I blow any grit out of the hole before removing spark plug.
Old Dec 10, 2002 | 12:53 AM
SVT150's Avatar
Removed the #2 plug and DAMN there was a lot of grit on the top of the plug.
Should I have blown any grit out of the hole before removing plug??
Hate to think ***** got in while removing the plug.
Old Dec 10, 2002 | 12:57 AM
blown318's Avatar
I would say blow it out.....
better safe than sorry ya know...
Old Dec 10, 2002 | 12:59 AM
cyntaxx's Avatar
do you have a loose coilpack that would cause so much grit to go in? i would check to make sure none of that gunk ends up grounding it to the manifold....
Old Dec 10, 2002 | 01:08 AM
SVT150's Avatar
Have a bad feeling some of that grap got in, coil pak was in good............got about 100 miles in it so far, we'll see
Old Dec 10, 2002 | 05:00 PM
SVT_KY's Avatar
Always a good idea to blow them before you turn them ... <grin>
Old Dec 10, 2002 | 06:08 PM
Jay Lincoln's Avatar
There is so much crap on the roads around here, the plug holes get filled with it.
I blow out the hole before I loosen the plug, then again after I loosen it a turn or so. that way, anything that may be trapped down at the bottom can be blown loose.
I also clean the coil packs as well. They get dust and grit on them as well.
Old Dec 10, 2002 | 06:42 PM
L in Detroit's Avatar
ive had many a problem with grit, and water, getting down the plug hole, all coils seem to be just where they should be but, twice so far I have had a hesitation at part and full throttle and it has been water down the holes, so bad even that 2 plugs I changes 5000 miles before were rusted , so I have it now on preventative maintence to pull the coils and blow out the holes..
Old Dec 10, 2002 | 07:22 PM
detail's Avatar
I usually just sweep the grit down in the cylinder to get it outta the way..
Old Dec 10, 2002 | 08:12 PM
SVT150's Avatar
L seems to be running fine, perhaps I'll add some Techron, just to be safe.
Actually, I can think of a few other things worse than a little dirt sneaking in.
Old Dec 10, 2002 | 09:11 PM
Lightningquick's Avatar
One good thing about having side exhaust,You get to hear your plugs dent the car next to do while you blow their doors off and your plugs tips off.
Old Dec 10, 2002 | 09:48 PM
rickgig's Avatar
Be cautious when blowing the crud out... it could get into the hole for the coil pack like mine did and cause a real pain for getting the bolt back in.
