Oil In Intake
Old Dec 8, 2002 | 12:48 AM
frank2's Avatar
Oil In Intake
Yes I know its an old subject,But DAMN,I took my intake off yesterday to port it out and there was oil EVERYWHERE.My Babolt single blade was covered,it basically dripped out as soon as I took the boot off.tubes were loaded too.I have a Breather and it was packed,oil must shoot thru there because it was allready goo-wy with oil,no wonder I use a quart per 1k. WHAT WORKS TO STOP IT,Breather sure as hell didn't
Old Dec 8, 2002 | 12:56 AM
The Orphaner's Avatar
Registered User
Question
There are many fixes im sure some will chime in here. I use a breather and an inline Oil-Seperator. While Sal will recommend using a 7/16" ball bearing installed inside the line on the passenger side valve cover. REM also sells a kit for this problem. But i just went to Lowes to fab. up a unit. So there are many choices.
Old Dec 8, 2002 | 12:59 AM
frank2's Avatar
where the hell is it coming from? just 1 side ?thru that little pcv thing or whatever you call it pluged into the valve cover on the passenger side?
Old Dec 8, 2002 | 01:01 AM
Registered User
Yes, most of it comes through the pass. side.
