stiffest lowering shock or spring?
Old Dec 6, 2002 | 11:38 PM
99REDBOLT's Avatar
Thumbs up stiffest lowering shock or spring?
i have a bell tech 2 inch front spring and a nitro active heavy duty shock. are ther any stiffer shocks that would keep the suspension stiffer going over bumps?are ther any stiffer springs but still lower like the bell techs?
Old Dec 6, 2002 | 11:55 PM
thepawn's Avatar
Stan can get you drop springs that are so still you'll lose teeth.
He can get up to something nuts like 1500lbs.
Daniel
Old Dec 7, 2002 | 02:42 PM
Ruslow's Avatar
There are stiffer shocks out there.But they are adjustable and not cheap so be prepared to spend some $ for them.Its the old saying 'you get what you pay for'If you by 30 dollar shocks that what you get.Plan on no less than 700 bucks for a set of 4 that are stiff enought to knock your teeth out when you go over bumps.Stan
Old Dec 7, 2002 | 05:25 PM
Shorty's Avatar
I use Eibachs and Bilsteins. I know some people don't like the Eibachs but they are pretty stiff and low. Best of all they aren't expensive. If you want a stiffer suspension, you might try prothane urethane bushings. Lot's of work but worth the effort.
