upper pulley ?
Old Dec 6, 2002 | 07:27 AM
predatr's Avatar
upper pulley ?
Can someone please tell me the pulley size for the 1 1/2 # and the #2 upper..somethin like 2.82/2.9
Anyone here running an upper with a #4 lower and what would u recommend.
Has anyone tried the JL or ASP upper with the puller?
thanx for any help
Old Dec 6, 2002 | 08:38 AM
99svtlightning's Avatar
I installed the ASP and the JL. The JL puller works the best. 10-15 minute upper pulley swap. I ended up having the ASP pulley pressed on at work. The JL aluminum looks great too. JL's pulley is closer to a full 2psi of boost. My ASP was around 1.5psi.
Old Dec 6, 2002 | 08:41 AM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
I believe the 2# upper is 2.8
Here's a link
With the 2# upper, a 4# lower, and 19 degrees here this morning, no ping-age
Be mindful of your tune.
Old Dec 6, 2002 | 09:00 AM
Rich B's Avatar
These pulley dimensions showed the following boost readings on an otherwise stock 01 engine.
Pulley size of 2.77" = 1-2lbs additional boost.
Pulley size of 2.84" = 2-3lbs additional boost.
I recorded these readings on an Autometer boost gauge (calibrated by Jackson Racing) within 30 minutes of each other. Your results may vary.
Rich B.
Old Dec 6, 2002 | 09:34 AM
Silver-Bolt's Avatar
RichB I think your numbers are reversed. Smaller diameter = more boost.
2.93" is the stock diameter. 2.80" is good for about 1.5lbs of boost.
