How many Lightnings out there blew motors?
I've seen a lot of posts about people blowing up motors and Ford not covering to fix it. How many of these trucks are blowing motors? Also, I've read a bunch of trucks blowing plugs which ruins the heads. Is this very common or only on heavily modded trucks?
Thanks,
Pete
Thanks,
Pete
Re: How many Lightnings out there blew motors?
later,
chris
When does a plug blow? Is it under WOT or at start up? I have a 96 Vobra now and check my plugs every few months and clean them off. Other than that what else should I have to do?
This was after a good ten miles of driving without boost.
The kicker is that i checked #5 just two weeks before with a cold engine and made sure it was tight.
I launched a plug under normal excelleration. This was with my 5lb pulley on, but I wasn't under that much boost, just accelerating from a stop light. When I went to pull the mods off and put in the stock plugs, I noticed a few of the plugs had loosened. I am kind of scared to put the 5lber back on now.
i belw mine. ate up 3 plugs, bent a vlave and put a nickle size hole in 3 pistons. JDM tuned superchip with an 11.78 A/F in the tables, 23 degrees of timing, and incorrectly calibrated for 90mm MAF. Mods were:
Intake
Flip Chip
4lb lower
90mm MAF
Crankcase filter
Boost By Pass
TR5 plugs
Traction bars
Driveshaft loop
at the Time
Intake
Flip Chip
4lb lower
90mm MAF
Crankcase filter
Boost By Pass
TR5 plugs
Traction bars
Driveshaft loop
at the Time
