Possible real reason to lean condition
Old Jan 16, 2003 | 12:17 AM
  #31
p_ferlow's Avatar
Just a thought but one could make up some fittings so that you run two filters in parallel and double your flow/filtration capacity?
Old Jan 16, 2003 | 12:59 AM
  #32
Tim Skelton's Avatar
Originally posted by Ruslow
. . . .that is one reason why the vast majority of the 'chips' can pass emissions.They only tune at wot. . . .
As usual, Stan is right on the money. I am an attorney who works for an aftermarket supercharger manufacturer. The reason they can get CARB certified is that the EPA driving cycle used to test the emissions for CARB is a simulated highway run which does not have the vehicle going into WOT. If the cycle required the engine to go into WOT, none would pass.
Old Jan 16, 2003 | 07:52 AM
  #33
99svtlightning's Avatar
You can make at least 500hp on the stock fuel system and more than that w/ a boost a pump or larger pumps. I think the stock fuel system is more than adequate...although I'm not sure about the fuel filter situation. I never had a problem on my 99 and I only changed the filter once in 25k miles. It ran 12.0's to 12.4's on average. However, I am changing my fuel filter more frequently, since it's fairly inexpensive to replace...just in case.
Old Jan 16, 2003 | 08:04 AM
  #34
LIGHTNINROD's Avatar
Here is an alternative Ford filter that I just installed:
http://198.65.157.241/galleries/pict...4298&anum=3208
http://198.65.157.241/galleries/pict...4297&anum=3208
It is listed for a 1998 Navigator(5.4). It has the same size end-tubes/connection and overall length but is way bigger in diameter/circumference. I removed the OEM clamp and used two, long hose clamps(in tandem, end-to-end) to attach it to the steel, 1/2"(?) line running just under the OEM clamp. I used a 2" piece of 5/8", reinforced, hose to fit around the steel line to protect the line and the filter body.
Dan
