Gator Belt????????????
Old Nov 30, 2002 | 12:45 PM
Blwnsvt01's Avatar
I was wondering where I can get the Gator Supercharger Belt for my 01 Lightning? I'm going to be installing the 4lb lower pulley and would like to replace the belt as well.
Thanks for you help
Blwnsvt01
Old Nov 30, 2002 | 01:02 PM
Don's Bolt's Avatar
When you order the belt, talk to your tuner they should be able to send a belt with the pulley.
Old Nov 30, 2002 | 01:05 PM
69Roadster's Avatar
I bought mine from Razor's Edge Motorsports. Autozone also sells them, may have to order it. RPM outlet has them online...
rpmoutlet
Or any other tuner.
Old Nov 30, 2002 | 04:13 PM
Odin's Wrath's Avatar
Got mine at Autozone. Only took a few days for the order to come through.
Old Nov 30, 2002 | 08:11 PM
cpeapea's Avatar
is it true that they break easier?
Old Nov 30, 2002 | 08:33 PM
Rob_02Lightning's Avatar
If mine didn't break, IT WILL NEVER.
I'll explain:
I had a problem once with a Chip and the SOB pinned the Tach to the ***** all night at WOT without ever allowing the Fuel/Rev Limiter to shut it down. I went at least 6500 -7000 RPM numerous times that night "ON A STOCK BLOCK" (OUCH) .
I wish I was at the track when it happen, the shifts were awesome at 6000+ RPM. I could feel the rods wanting to come out that night But no broken belt
Old Nov 30, 2002 | 08:40 PM
BTW
At the time I was running my summer setup with an extra few lbs of Boost. I run a 2-3 lb upper and a 4lb lower in the summer.
""I MUST BE A LUCKY ONE WITH A STRONG BOTTOM END HU ?"""
Old Dec 1, 2002 | 04:17 PM
Blwnsvt01's Avatar
Thanks for your help I checked autozone and they do have it for 28.99 with stock pulleys. I going to be upgrading to the 4lb lower pulley so I'm hoping that i get a new gator belt with the new pulley, if not then i will order one at Autozone.
Does anyone happen to know the part number for the Gatorbelt for a 4lb lower pulley and a stock upper pulley?
Thanks again
Blwnsvt01
Old Dec 1, 2002 | 07:03 PM
Lightninforce's Avatar
Cool Gatorback belts
Our interchangeable lower pulley kits come complete with the proper Goodyear Gatorback belt.
Mark/LFP
www.lightningforceperformance.com
