Belltech 3-4 drop, What Shocks?????
Old Nov 27, 2002 | 03:13 AM
speedRacer5's Avatar
So after reading through the forums I decided I should drop my L with Belltech. But some of you said not to use their shocks, so what shocks should I use?
Old Nov 27, 2002 | 03:56 AM
whitetoast11's Avatar
Ruslow will sell you correcly modded qa1's that I beleive fit just fine, check over on ruslow's forum over at nloc.net.
~Toast
Old Nov 27, 2002 | 11:26 AM
RTKILLA's Avatar
doestch shocks are pretty nice for a 3/4 drop kit. I switched to them and I like them allot more then the bell techs.
Old Nov 27, 2002 | 12:27 PM
Thanks guys, I have another problem, I went to order the belltech kit and they said they didn't make a 3-4 drop kit?? What's up with that, I called them direct?
Old Nov 27, 2002 | 12:42 PM
RTKILLA's Avatar
tell them you want a regular F150 3/4 drop kit. L's are lowered from the factory so they might be thinking you want to go 3/4 on a L which is only 2/ 3to4 drop.
If not F150 has the kit at the online store. You want the bottom one https://www.f150online.com/cgi-bin/f....html&CODE=144
you can get the shocks from www.sporttruckdirect.com also.
good luck
