hitch removal what gains?
i want to remove my hitch (nothing to tow) and was just wondering how much it was worth as far as E/T reduction and relative hp comparison ie 100 lbs. reduction = 10 hp right?
i'm not sure about the "formula" and is the 10 hp at the wheels? just need a bit more detail
thanks in advance.
thanks in advance.
Looking at it from a power-to-weight ratio viewpoint (from my Web site):
"Removal of the spare, jack, and trailer hitch alone should shave off 120-150 lbs. Shave off a total of 200 lbs. (4.3%) and the net effect on power-to-weight ratio is the same as adding about 15 HP--in addition to the handling improvements."
cyntaxx
Most feel 100 lbs off will add 1/10th on the 1/4.
As for removing the hitch, DO IT. I took mine off and love the new clean look. It's only 6 bolts (if I remember correct) and it takes only ten minutes or so. You'll need a 1/2 drive breaker bar and a piece of pipe to break them suckers loose though, mine must have been put on by a Gorrila, dam they were tight. I then drove straight to the track and ran my best time ever
next track run will be less the tire, who knows ???
One time I got the bright idea to add wieght to my truck and melted over 50lb of lead and put it in the tube in that bad boy. Oh was that a mistake I wanted more traction I didnt really find it so when i took it off that was a mean job. So my advice is to take it off. I too ran my best time after the delete.
with that same setup other than the hitch.
As soon as I picked it up from the dealer, I wanted that ugly thing taken off
Before I run, I take out the spare and the jack.
The hitch is eight bolts (with washers), and is a five minute install (de-install lol??!?!)
If you are worried about loosing traction in the rear because of less weight, then just re-locate the battery back there.
Remove hitch - less weight in rear & truck overall
Relocate battery - less weight in the front and more on rear tires without increasing overall weight of the vehicle.
yes unload i may. email me here: cyntaxx@yahoo.com
bob: yes i may drive it in the winter but only on the fair days w/ no snow so i dont need the weight in the rear...
damn, to bad i cant remove mine i.e WaveRunner/Winter Driving/other towing stuff.
see i dont have the luxury of the L, being my summer/race ride. i got the cobra for that. i had a 2000 Ranger for my "work truck" (yard work, towing etc.) but then i got the Lightning cause it was awesome, and im doing mods (appearance & performance) but i still need the little things to keep it useful. ( i got a regular tonnau so i can easily remove for hauling) ( the hitch for towing) (and i put the bed liner so i dont scratch it up with yard work stuff, and garbadge like that)
unless i store the lightning this year and drive the cobra.... hmmm......
isn't the weight at the extreme rear of the truck improving the balance of the truck's front-to-rear weight distribution and helping to increase traction???
