Foggy Tail light!
Old Nov 20, 2002 | 05:17 PM
BlkBanshee's Avatar
Suspended Pending Email Reply
Angry Foggy Tail light!
Walked around the back of my truck today when rotating the tires, to find... A FOGGY TAIL LIGHT!
I'm going to the dealership tomorrow, and they'd better replace it...
Has anyone had a problem with this?
Old Nov 20, 2002 | 05:24 PM
beefcake's Avatar
passenger fogged from almost day 1, got it warrantied
1 week after being fixed drivers side started fogging
fixed under warranty
they also fixed my fog lites under warranty too
Old Nov 20, 2002 | 05:26 PM
SpankDog's Avatar
Banned
I also had my tail lights replaced under warranty, fog lights too.......and they are cracked again.
Old Nov 20, 2002 | 05:39 PM
RTKILLA's Avatar
you know my dealer wouldn't fix my fog lights ever on my truck. I've had a broken fog lamp for the past year and I'm not going to fix it cause I never use the damn things anymore anyway. you get tired of constatly fixing them.
Old Nov 20, 2002 | 05:48 PM
Fast Gator's Avatar
Thats funny, cuz my dealer replaced my fogs 3 times already, under warranty.
But the foggin tail lights, thats one I don't have, unless............
have seen the truck in two weeks, maybe I better go out to the garage and see if she's still in there
Old Nov 20, 2002 | 06:13 PM
E-LO's Avatar
someone posted about this a just a while ago and there is a simple fix for the tail light deal.
Old Nov 21, 2002 | 03:07 PM
Smurfslayer's Avatar
Post that'd be me...
I've got a fogged tail light too. The solution was quoted to me as remove light, let dry, duct tape holes that allow all the water in, reassemble.
I confess, I haven't fixed it yet, been a bit busy...
Old Nov 21, 2002 | 08:05 PM
LIGHTNINROD's Avatar
My right one was 'foggy'. I took a Unibit and drilled a small hole at the rear and another one on the front-side. No more condensation.
Dan
Old Nov 21, 2002 | 09:03 PM
Krix330cic(NJ)'s Avatar
LIGHTNINROD My right one was 'foggy'. I took a Unibit and drilled a small hole at the rear and another one on the front-side. No more condensation.
Is there anyway possiable you could show me where you drilled these holes?
Old Nov 22, 2002 | 10:45 AM
Krix: I'm 'computer illiterate' so I can't post a pic---and I got a dig. cam a few months ago--just pitiful .
The hole in the back is about 1" up from the bottom edge and the hole is facing straight back. The hole on the side is about 1" above the bottom edge in the lower, front rounded edge. I don't think it makes a whole lot of difference just where the holes go. I just wanted air to be able to flow through the lamp assembly.
Dan
Old Nov 22, 2002 | 03:05 PM
Rich B's Avatar
Both my rear tail lights had condensation in them. The drivers side was worse. Just didn't have time to get it to the dealer for replacements. Sunday I popped out both lights and did the duct tape thing. I really didn't think the tape was going to fix anything. Since then I have driven in heavy rain 3 days and my tail lights are crystal clear.
Rich B.
Old Nov 22, 2002 | 03:06 PM
thanks man, ill try the dealer first (warrenty) and if they wont replace, ill try your way!
Old Nov 22, 2002 | 04:05 PM
Fast Gator's Avatar
Hey Chris, how did you make out on your fogs? Never heard back from you on the trip to All American
Old Nov 22, 2002 | 06:09 PM
Bruce, we were on our way to an appointment with a realtor down the shore, so we stopped in at Oasis, and they put the new ones in, in like 15mins.. perfect so far!
Old Nov 22, 2002 | 06:43 PM
DennisWeise's Avatar
The problem seems to be the mounting screws. When the tail light assembly was installed, if the mounting screw was over-tightened it cracks the plastic and allows water to enter at that point (directly behind the red lens). The water then condenses on the clear cover lens. New ones will do the same thing unless you point this out to the mechanic.
Any Ford dealer can service SVT vehicles, but I would certainly use an SVT certified dealer to do engine/drivetrain work.
DW
