Went to Dyno both of my chips here the results
Hi, My Mods are straight pipes K&N cone filter, 2LBS PSP lower pulley and NGK TR6's, First run was made with a Superchips chip, i don't know much about A/F numbers but the Dyno guy said that it was running a little bit lean, what do you guys think?
Here the other run that was done with a PSP chip, now on this one the dyno guy said that the A/F numbers were right one but for some reason the power just stars droping drops at 4700rpms! you guys have any ideas of why is it doing that?
Should I sent my chip for a reburn or what should i do? thanks a lot for any help.
does the truck shift at 5000 rpm? it should there is no reason to run it higher than that. I would probably get a reburn. Did you dyno the truck without a chip? Those are mild mods and you may make more power without it.
yeah that superchip is on the high end of the A/F.
who's truck shifts at 5000 rpms with a chip??? not mine, most shift at 5300 to 5500 with a chip. 5000 is to low for a perfomance chip. if you have a easy driving program, sure then.
Well, the Superchip is definitely way too lean for pump gas. That's where the extra power is coming from. But on pump gas, that'll burn a valve or plug in a hurry. That chip would work well with some race gas though.
The a/f numbers on my chip are exactly where I shoot for, 11.7ish, for pump gas. Looking at the numbers, and how they drop suddenly, it looks to me like the dyno guy forgot to shut the overdrive off for that pull, and it shifted into 4th.
Hope this helps.
Hope this helps.
the FLP guys know their stuff....they're a quality dyno place.
as for your truck shifting..yep 5400 sounds right...definitely not 5000...
your A/F on the first one is a bit lean...i'd get it richened up a tad...the PSP one is pretty safe and i'd run that in the winter...
also...the straight pipes might lessen your torque down load a bit...but i dont have exact #s for ya....loss of backpressure tho
Hope this helps.
Hope this helps.
Originally posted by LAST50
Where did you dyno at? FLP? Street stuff?
Hmm ok. Well something funky is going on. I've never seen a truck drop like that without it being something mechanical. The truck dropped 40hp and 50ftlbs all in one shot within 100 rpms and the a/f didn't change at that point, so it doesn't really look chip related. Do you feel that drastic drop on the street? It REALLY looks like the truck shifted into 4th. Do you have the graphs?
Wow, that is just weird as heck. The A/F looks great, the power curves look great, and then that drop at 5k. Well, pull the chip, and let me know what the file names are off it (on the white label on the front) and I'll check the programs. Could be a limiter or something that was missed, or some kind of a glitch. I doubt it, but I'd still like to double check it.
1.CUX2 2 C2SE355
PCM:CUX2
Thanks for the help Sal.
