changing rear diff fluid...
Old Nov 18, 2002 | 10:28 AM
clonetek's Avatar
i'm wanting to take the rear diff cover off and sand/paint it.. also change the fluid while i'm there...
what paint should i use? and should it be primed?
what diff fluid should i use? i've seen mobil 1 syn in the parts stores.
is there an additive i need to put in there? what is it?
gasket? is there one? or do i use RTV?
torque specs on bolts?
i figure i'll need a pan to catch the fluid, some hand tools, a camera, a leprechaun, and other stuff... any pointers?
is there a magnet in there that needs to be cleaned?
i'm at 45k miles, i figure the fluid needs to be changed.
Old Nov 18, 2002 | 10:43 AM
yysenhimer's Avatar
(I wouldn't paint it. I would just get one of those powder coated covers or something)
Use a high heat paint
You only need to prime it if you strip the old paint down
Ford recommends synthetic fluid (I forget the weight)
Not sure about a friction modifier, but I don't think it is required with synth fluid
Just use RTV to seal it
You'll prolly need a hand pump to pump the new fluid in after you put the cover on, and an air freshner because gear oil stinks
Old Nov 18, 2002 | 11:01 AM
clonetek's Avatar
the diff cover is pretty much covered in surface rust.. looks nasty, and rust is bad..
i wanna at least make it look better than that rusty thing... maybe a aftermarket diff cover with a fill hole?
nothing flashy, i prefer function over form.
Old Nov 18, 2002 | 11:12 AM
svt360's Avatar
i dont remeber the company but i seen it in muscle mustangs and fast fords,its a dif cover that resembles a quick change rear,looks pretty cool i will be getting one over the winter,it also stifens the carrier,and is aluminum
Old Nov 18, 2002 | 11:16 AM
easterisland's Avatar
I used mobil 1 synthetic fluid. I also added a friction modifyer. The tag on the diff says to use one type of oil while the owners manual says to use another. So who really knows what should be used?
Old Nov 18, 2002 | 11:36 AM
quiksilver's Avatar
I use Redline synthetic gear oil in all my toys, it has the friction fodifier for posi's in it allready, has a wide viscosity range, and frees up some ponys.
Old Nov 18, 2002 | 11:38 AM
yysenhimer's Avatar
Are you talking about the generic manual or the SVT Supplement? (I haven't looked). I would go by what the diff tag says.
Old Nov 18, 2002 | 11:45 AM
The SVT hot line guys told me do what the manual says.
Old Nov 18, 2002 | 11:51 AM
Don's Bolt's Avatar
Thats funny I talked to SVT and they told me to go by the tag on the differential.
Old Nov 18, 2002 | 12:01 PM
Tim Skelton's Avatar
Here is function and form! Just finished this yesterday.
Fitted the Ruslow panhard mount to a Mag-Hytec diff cover. Twice the fluid capacity, magnetic drain plug, o-ring seal, port for AutoMeter temp sender, magnetic dipstick. $245.
There are, however, conflicts with the anti-sway bar on lowered trucks. Have not done the fitting yet, but I think that the anti-sway bar mounts will need to be raised (and the endlinks commensurately shortened -- I'm ordering So-Cal adjustables today).
I do not think that there are any other aftermarket diff covers available for the 9.75 rear.
Old Nov 18, 2002 | 01:19 PM
RTKILLA's Avatar
I got to do that to brooks. good thing you posted this.
I know JL has a cover on his site.
Thad's Avatar
Try this site; http://www.fordf150.net/howto/differentialfluid.htm
Tech article from this site.
Old Nov 18, 2002 | 01:43 PM
I'm sorry I didn't notice this earlier. What the SVT specific manual says. Motorcraft SAE 80W-90 Premium Rear Axle Lubricant.
They also note that you must also add 118ml of Friction Modifier.
Also note that the manual says,"Your vehicle's rear axle is filled with synthetic rear axle lubricant and is considered lubricated for life."
Old Nov 18, 2002 | 04:35 PM
2001SVT's Avatar
You're choice, Stock is synthetic. I use redline.
Yes if the fluid you use doesn't have it in already. Many do including redline.
No gasket just use rtv.
No but it is a good idea to wipe out the bottom of the punkin.
What easter said about "considered lubricated for life" is correct however when I changed mine out at 5k it was very dirty and gritty so its not a bad idea.
Old Nov 18, 2002 | 06:39 PM
Skank Dog's Avatar
I switched to Royal Purple 75W-90 diff. fluid and oh man!!......You could actually feel the truck squat a little lower and spin the tires more freely on acceleration after the fluid change!! Not much impresse's me anymore, but Royal Purple fluids do! I now have RP fluids throughout my drivetrain and love the performance gains!! There is no need to add friction modifiers with RP, they're already in there! Hope this helps.
Rodney
