Where can i get the 32v 5.4L motor?
Old Nov 17, 2002 | 06:00 PM
is300lex's Avatar
Other than the supercharger and forged pistons( and of course the heads) what is the difference between a 16v 5.4L and the 32v 5.4L. I am considering doing a swap and was wondering the pros and cons of that motor, and where to aquire one cheap. also, has anyone done this yet? Is this a good idea? or should i just build up the stock motor?
thanks
Old Nov 17, 2002 | 06:25 PM
J15BIG's Avatar
the only 4V 5.4 I have seen (other then the Cobra R) was from SHM. I dont have specifics but basically what I heard was that it didnt perform much better then our 2V motors and was not worth the money. I would rather spend 14k(the conversion cost that much) on a built motor with ported and polished heads, a whipple 140, and a nice nitrous setup, and still have a few grand left over.
Old Nov 17, 2002 | 07:30 PM
is300lex's Avatar
I know the navigator comes with the 32v 5.4...what is the cost of that motor? anyone know?
Old Nov 17, 2002 | 07:45 PM
Redneck Ferrari's Avatar
Headline: 5.4 DOHC 4 Valve Engine For Sale website link 13908
1999 Ford 5.4 DOHC 4V V8 Engine 9,980 miles 350 + HP 400 FP Torque, Forged Crank, Rods, Pistons, Ported & Polished Heads, Excellent Shape. Complete from Throttle Body to Oil Pan, including Engine Wiring Harness. $4500.00 OBO.
click for fullsize image
Listed By:
John W. Riley
Henderson, NV USA
(702) 480-9271
I'd say $4500. I know that JR is building some very good motors, especially his.
Old Nov 17, 2002 | 07:46 PM
cyntaxx's Avatar
does the nav. motor have anything forged in it?
maybe its time to start searching for wrecked 2000 cobra Rs to get a 4v 5.4 (with carillo rods!!)
Old Nov 17, 2002 | 07:55 PM
Thor01's Avatar
It's not just a matter of the mechanics. Calibration is another issue. You will need 49# twin spray injectors. If you do not use the twin sparay injectors you will burn the intake valves. You can get away with 52# depending on th tuner and the corrections he makes in the tables. Then the transmission will be the other factor!
A well calibrated 5.4l 4V will produce well over 500RWHP if done right.
Best of luck and never go with single spray injectors on a 4V.
The new 03 Cobra has twin spray. Think about it.
Thor.
