Belt?
Old Nov 15, 2002 | 08:27 PM
Cali L's Avatar
Belt?
Is there a trick to removing the belt? I've never done it before. Is there a sprung tension pulley or do you pry it off? Any how to's would be much appreciated.
Old Nov 15, 2002 | 08:44 PM
I8ACAMRO's Avatar
I'm assuming the S/C belt, all you need is 1/2" braker bar or 1/2" equivalent. The belt tentioner has a slot for the 1/2" tool.
Old Nov 15, 2002 | 08:46 PM
Masterloggie's Avatar
Cali L,
Facing the truck look at the tensioner pulley on the SC belt (left). It is on a tensioner arm. Take a breaker bar and pry it to the left. You will notice there is a stop molded in the casting od the tensioner. You can take a large screwdriver and break it off easliy. Makes it easier to remove and replace the bely espacailly when changing lower or upper SC pullies.
Ron
