Question for nitrous people???????????
Old Nov 13, 2002 | 09:16 AM
chimshady1's Avatar
Question Question for nitrous people???????????
While i got my intake plenum off ,i was wondering if it would be o.k. to tap the nos jet into the middle of the plenum.Would this be advisable?
Old Nov 13, 2002 | 09:52 AM
beefcake's Avatar
http://www.powersurgeperformance.net...pexd.asp?id=51
1BADTK's Avatar
Careful where you put it, hood might not close.
Old Nov 13, 2002 | 09:55 AM
chimshady1's Avatar
1badtk=I think i might be able to get a right angle fitting to clear the hood.If not i might be ablle to fit it on the bottom side of the plenum.Has anybody done this before?
Old Nov 13, 2002 | 09:58 AM
beefcake's Avatar
chimshady, spend the 75 bucks on that link i sent ya, the nitrous plate goes between the throttle body and intake and works awesome
Old Nov 13, 2002 | 10:24 AM
easterisland's Avatar
When I was running the dry shot I drilled a hole in the side of the intake plenum behind the egr valve. It threaded easy and worked well.
I now have one of Sals plates and it also works okay. Problem is it doesn't match up good with the openings on the throttle body and intake plenum. It is also hard to change the jets.
Bottom line is if you don't mind drilling the plenum then do it that way and save the money.
Old Nov 13, 2002 | 11:35 AM
BlkBanshee's Avatar
Suspended Pending Email Reply
I thought that plate was supposed to go between the intake plenum and supercharger....
Old Nov 13, 2002 | 11:55 AM
RTKILLA's Avatar
I new a kid with the jet taapped right into the plenum also. It was on the passenger side right after the TB so it was right out in the open for changing jets. It was nice, but I like mine hidden kinda with the PSP plate.
Old Nov 13, 2002 | 11:57 AM
Nope, you thought wrong.
Old Nov 13, 2002 | 12:14 PM
tommylightning's Avatar
I have mine in the plenum as it was too hard to change the jets with the PSP plate.
Old Nov 13, 2002 | 02:03 PM
1BADTK's Avatar
No right angle fitting will work with the NX Shark Nozzle, Must be a straight shot to the nozzle tip.
Old Nov 13, 2002 | 02:28 PM
chimshady1's Avatar
I guess i'm gonna tap into the plenum.From what your saying about the plate not matching up to well and being hard to change jets.Thanx guys,gotta love the forum.
Old Nov 13, 2002 | 02:55 PM
beefcake's Avatar
lmao,
the plate matched up fine on my truck,
on top of that, how often r u going to be changing the jets?
2 or 3 times a week?
Old Nov 13, 2002 | 03:01 PM
lmao, of course it fit yours perfect.
Old Nov 13, 2002 | 03:07 PM
beefcake's Avatar
btw, easter,
check the "gen 2 list"
the pathetic power surge trucks are doing pretty well,
sal is the fastest gen 2! and the quickest!
and i'm in the top 15 if i'm not mistaken,
not bad for pathetic losers huh
your such an a$$
