99-00 01-02 computers
Old Nov 13, 2002 | 02:38 AM
Black SVT's Avatar
The 99-00 computers are different than the 01-02 right?
A chip from a 01-02 wont work in a 99-00 right
Old Nov 13, 2002 | 03:30 AM
RAN JR's Avatar
Re: 99-00 01-02 computers
not unless it is reburned. the 01-02s have 90mm mass air meters & 3.73 rear gears
Old Nov 13, 2002 | 04:46 AM
cyntaxx's Avatar
nope diff codes...cux as opposed to abu i think
Old Nov 13, 2002 | 06:11 AM
Rob_02Lightning's Avatar
My 02 is ABU-2
Old Nov 13, 2002 | 07:26 AM
ema100c's Avatar
Originally posted by Rob_02Lightning
My 02 is ABU-2
Rob,
Where do I look to see what version computer I have in my 01 L?
Thanks,
Eric
Old Nov 13, 2002 | 08:28 AM
DHFerguson's Avatar
There should be a little white sticker inside the right door jamb, near the computer (which is under the right end of the dash).
Old Nov 13, 2002 | 10:06 AM
LightningTuner's Avatar
99s are CUX1
00s are CUX2
01s are CXN1
02s are ABU2
Some 99 trucks have been reflashed by the dealer to CUX2, as it's a standard Ford update. There are no updates for the other 3 calibrations.
You can't use a chip from one of the 4 calibrations on a different one. And if you have a CUX1 that's been reflashed, you need a CUX2 chip. Hope this helps.
Old Nov 13, 2002 | 11:49 AM
TYT-LYT's Avatar
So a dealer or anyone couldn't flash say a 99 or 00 computer to 01 or 02 specs?
Old Nov 13, 2002 | 11:52 AM
Well, you could if you wanted to. You can flash a 99-00 to an 01, but not an 02. However it is not an approved Ford update, and it's also against the law, so you might have a hard time getting a dealer to do it unless you know someone there.
Old Nov 13, 2002 | 12:48 PM
Black SVT's Avatar
Ok the chip is outa a 02 with a abu2 can it be reprogrammed for a 00 cux2.?
Old Nov 13, 2002 | 12:50 PM
Sure, any chip can be reprogrammed for whatever you need.
Old Nov 14, 2002 | 10:54 PM
99Lightning's Avatar
Sal, why did Ford decide to do this?
Old Nov 14, 2002 | 11:19 PM
Ford updates calibrations for many reasons such as calibration errors, drivability problems, gas milage issues, etc. The CUX1 to CUX2 recalibration is strictly for EPA reasons, as has to do with emmisions. It is not performance related, and does not help, or hurt performance.
