Guage lights all out help!!!!99 lightning
Old Nov 11, 2002 | 06:29 PM
tms217's Avatar
Exclamation Guage lights all out help!!!!99 lightning
I went to dim the dash lights and poof all of the guage ilumination went out. I still have all of my other lights though. I know all of the fuses are good and I checked to see if any wires came loose but everyting seems to be ok. The only thing I can think of would be the little relay screwed to the back of the guages.... Anyother options???? Please help..
Terry
Old Nov 11, 2002 | 06:37 PM
svt4rd's Avatar
check connections at the headlamp switch... the dimmer switch and again in the multifunction switch
Old Nov 11, 2002 | 06:50 PM
LIGHTNINROD's Avatar
The rotating dimmer may just be 'dirty' internally. Try rotating it back and forth rapidly to see if you can 'clean' it.
Dan
Old Nov 11, 2002 | 07:19 PM
tms217's Avatar
The dimmer still works the odometer and radio so I don't think it is that.....
Old Nov 11, 2002 | 07:31 PM
NJ SILVERBULLET's Avatar
dash lights
The exact same thing happened to my 2001 L when it was only 1 week old. The "luminesent" lighting of the gauges went dark, but all of the other lights on the dash, radio, heat/ac controls, & power window buttons all still worked just fine. The dealer had to replace the gauge cluster and code 2 new keys to go with it. They said they had never seen that happen before. It's been fine ever since, about a 1 1/2 years. Go see your dealer and I hope you got the extended waranty. Good luck, hope this helps.
