Dual or Triple Guage pod for L?
Old Nov 8, 2002 | 07:24 PM
ShaneMcKenna203's Avatar
Hey i have a Lightning and i uped the boost with a 4# lower and im looken to get an auto meter guage. I HAVE an air fuel guage i am going with 2 and 1/16th my question is, go dual pillar or triple pod? What should the 3rd pod be? Water temp? How important is that? if anything i'd like trans temp, i just heard install was hard on trans and fuel presure...
any tips on installing air fuel and boost guages?
also If i can get pics of info on what ya recamend for me, i found the pods for like $50 from summit that sound right? thanks again, Shane
Old Nov 8, 2002 | 10:42 PM
air1kdf's Avatar
Go for the three pod.
Fuel pressure is a synch to do, DONT forget the 3280 adapter.
EGT is also a good gauge to get.
Summit, egauges, etc. Both ship very fast.
Tip: also get that plastic wrap for wiring harnesses. I fitted this tube on all of the gauge wires first, then I only had 1 piece to fit through the dash. You can't tell the difference between the factory wiring harness, and my setup. The down side is that I probably spent 20-30 hrs by the time it was all said and done.
Old Nov 8, 2002 | 10:58 PM
TYT-LYT's Avatar
I did the 3 pod, with boost, air-fuel, and trans temp. All autometer/lunar. Trans temp was probably the easiest, There is a small bolt above the tranny pan on the drivers said that you take out and the sender screws right in! Like it was made for our trucks. Air-fuel isn't too hard, just splice into the O2 sensor on the drivers side, its kinda a PITA to get up to it. Then the boost was easy, just get a t-fitting and elbow. It wasn't very hard, you just gotta be patient. email me and i can go in-depth with everything if you need me to.
Keegan
