Nittos ?
Old Nov 6, 2002 | 08:17 AM
Marc Carpenter's Avatar
Nittos ?
I have seen several Lightnings drive into the track with the Nitto drag radials on their trucks. So I must believe that they are road worthy.
What I would like to know is anyone also using a Nitto on the front of thier Lightning ? I really hate to change my tires when I arrive at the strip, so I was thinking that maybe I will get a set of the drag radials for the rear, and a set of the regular Nittos (something that hopefully matches in apperance) for the front.
What size do you who have them use ?
Need your input.
Marc
Old Nov 6, 2002 | 08:28 AM
beefcake's Avatar
obviously if the drag radials are fine on the rear of the truck, the regular nitto is going to be fine for the front
it's a street tire like any other
unless your question was putting the dr's on the front, i probably wouldn't do that unless your doing some road racing
Old Nov 6, 2002 | 08:37 AM
lets make it easier.....
Has anyone here tried running the 295/45ZR18 Nitto on the front and the 305/45R18 Drag radial on the rear of their Lightning??
Will the difference in height set off the ABS light ?
Anyone?????
Marc
Old Nov 6, 2002 | 10:09 AM
beefcake's Avatar
i seriously doubt it, i've run from 26" to 28" slicks on the rear and never set an abs light
Old Nov 6, 2002 | 10:29 AM
BlkBanshee's Avatar
Suspended Pending Email Reply
Marc,
You're only talking about a 45mm difference in height. Not even enough to notice a change in the speedometer.
Now, one thing I HAVE seen, is people TEAR through the Nitto 555R's.... A friend of mine barely pulled 8,000 miles out of a set on his RX7.... His next set was the Yokohama A032R... Those almost lasted 10,000!
Old Nov 6, 2002 | 10:31 AM
easterisland's Avatar
Anyone?????
Marc
That is exactly what I have on my truck. It works good.
There is almost difference in height and the ABS light has never came on.
Old Nov 6, 2002 | 10:53 AM
Okay easterisland tell me.....
Now that I have found someone who has the set up I am looking at please tell me how you like it.
I really get tired of changing tires at the track, and I really like to run the DOT classes, which I can not do now with the Hoosiers.
Have you had them on long ? How do you like them ? And etc. and etc. Do they look the same in apperance front to back tire wise ?
Thank you in advance for any info.
Marc
Old Nov 6, 2002 | 11:05 AM
They look close to the same in appearance. The nitto hook better on the street than do the F1's. I would still switch them out at the track for some DOT slicks.
Old Nov 6, 2002 | 11:26 AM
I thought you said you have the extreme drags on the rear of your truck, and the 295/45zr's on the front ?
It is my intention to keep the 305/45R18 extreme drags on the rear, and the 295-45zr's on the front at all times, so I don't have to change at the track.
I very seldom drive my Lightning unless I am going to the track or maybe a local cruise in. Realizing the Nittos will only last around 10,000 to 15,000 miles. And I have Never been in the rain so that is not a problem.
Marc
Old Nov 6, 2002 | 11:29 AM
beefcake's Avatar
they're fine in the rain
been my daily driven tire for about 4 to 6 months now
Old Nov 6, 2002 | 11:36 AM
What do you have on yours Beefcake..
Do you have the extremes on yours all the time in the rear, or are you talking about the 295/45zr18's?
I am not sure that everyone understands that I want to run the drag radials on the rear and the 295/zr's on the front, ALL THE
TIME. I do not want to have to change over to them at the track all the time. And 90% of my street driving is on the way to the track.
Marc
Old Nov 6, 2002 | 11:48 AM
I thought I was pretty clear, here are the different tires and wheels in my possesion as of today.
I have nitto tires on four chromed stock 18" 2001 wheels. The tires on 2 of the wheels are the nitto 555r 305/45/18 drag radials the ones on the front are nitto 555's 295/45/18.
I also have 6 2001 stock wheels 4 with good year F1's and 2 with nitto 555r's 305/45/18.
I also have 2 16x8 aluminum wheels with 28x10x16 hoosier slicks.
I have on order the following with which I plan to run the Nitto 555's on front and 555r's on the back with a set of hoosiers on the 16x8's:
2-16x8 weld prostars
2-18x8 weld prostars
2-18x9.5 weld prostars
I drove mine daily with the nittos and loved it. I'm going the same route this next time with the new tires. Excellent idea-unless you don't have the extra money to purchase new rear tires occasionally. If you fall into that group go with the F1's or regular nitto 555's.
Old Nov 6, 2002 | 11:54 AM
I stand clear now.
Thank you very much.
marc
