Side View Mirror Turn Signal ??
the painted cap pops off. you will have to turn the mirror in both directions , use a long thin srewdriver to lift up on clips behind mirror on top. after pulling cap off ,turn bulb socket out to get to bulb. bulb # is 921. if the bulb is okay then you will have to take off the door panel to get to the wiring connections for the turnsignal.known problem for the driver side wiring connector to come lose. if lose you should hear a rattle in the door.
I havent got the painted cap off yet. I see some small metal clips on the top behind the mirror that are horizontal but i was pushing on them and nothing happened. Its cold as hell out side and I am afraid i'm going to break something plus I was using a little flashlight that put out some weak light. I am going to try ang get a better look at it with a better flashlight so anything else you could think of would help. Thanks
