Razors Edge Air intake Tube
I got one in black. Dont know about more hp but sure looks good hehe
. One tip though have a dremel handy if you are gonna get one as you need to dremel down the lip on the MAF to get it to fit. Also the little rubber T in the bottom of the boot that the vacum line gets connected to is a bitch and likes to come out easy. Other then that i like it. One more thing i have heard though is that anyone that uses it and has the oil in the intake boot problem is getting the oil coming out of their air filter. Since im guessing the ribs in the stock boot caught the oil before it leaked to the filter. Im fine though since mine is bone dry and i dont even run a breather
I didn't use a Dremel but just a 3/8" drill with a burnishing bit. It took the lip off.
There should be no problem reinstalling the OEM rubber boot as the clamp will keep it tight and in place.
Dan
Dan
