HELP!!! truck problem!
Originally posted by LIGHTNINROD
Plugs(as everyone says) and/or clogged exhaust???
Dan
Dan
clonetek
The easiest thing to do is like Tim said, start it up, and unplug each coil and see if one or more show no change when you unplug that coil (AKA the bad plug)
well, i unplugged each coilpack one at a time with the truck running.. each time it made the truck run rough & stumble...
pics of a plug that i pulled.. (same plug in each pic)
http://svt.kicks-***.net/images/spark/
gonna go pull some more plugs now..
well, the front 2 plugs on each side look fine..
i also checked my MAF & boot, took chip out, cleaned contacts, and reset computer.. gonna go test drive real quick.
hopefully i'll be able to get to the back 4 plugs tomorrow morning.
(i work graveyard shift.. its time for bed!)
i drove it & it still did the same thing.. but i got to thinking..
at world ford challenge 4, speedin bob adjusted my boost actuator for me.. i had the 2lb pulley then.. would the 4lb pulley screw that up?
i was thinking some more & decided to stop at ricer central (aka: autozone lol) and get some fuel injector cleaner..
put it in and the problem has started to go away.. i'll test it out some more tonight on the way to work.
Hey Brooks
By any chance have you gone to the track and got any race fuel lately. If so you may have gotten some leaded fuel my mistake. If so you may have clogged the cats.
I don't know just a guess from a long ways away
no race gas..
i really don't wanna have to pull those back 4 plugs.. hmm
hey don.. how hard was it to pull the blower/intercooler off?
i may just take everything off & clean it... then change those damn plugs.
Originally posted by clonetek
no race gas..
no race gas..
The blower is held on by 8 13 mm bolts, and you have to unscrew the pcv tube along with some vacuum lines. The intercooler you have to remove the coolant lines and about 5 bolts at the back od the intercooler. The 8 bolts that hold the supercharger act as the front and side bolts for the intercooler.
clonetek
Here is what you need to change the plugs with.
Shawn changed my plugs at FFW Ennis in less than 30 minutes.
The short extention w/ socket from the second to the right is not needed. It was found on my wiper cowl while that was done. I gave that to Shawn courtesy of Bankston Ford.
I believe Shawn only took off a couple things when he did the plug change. The boot and MAF and one of the hoses that was connected to the bottom side of the boot was removed for the driver side plugs to be reached easier. I believe that was the only things that he took off. I think he moved something else to the side, I would just have to go look under the hood again to see what it was exactly.
To remove the coil packs, Shawn used an 1/4" drive extention 18" long with a 7mm whobble socket and ratchet. He used the magnet on the right to put the bolts back in the coil packs when he was installing them back in.
He used a 3/8" drive extention about 24" long, a very deep 5/8" socket connected to a whobble joint, and a ratchet to get the plugs out. Shawn made it look so easy it was fricking unbelievable.
Also, did this start happening after you put gas in it. You may have just put bad gas in it if the injector cleaner helped some.
