Stock Jack!
Old Oct 26, 2002 | 07:42 PM
frgetit's Avatar
Angry Stock Jack!
A few weeks ago, I got a flat with the L. Sidewall puncture. Have any of you ever attempted to jack up your L with the stock ford equipped jack? Yeak...ok....that's not gonna happen. I placed the jack at the lowest point and at FULL height it didn't even LOOK different. So I had to call a wrecker, to bring a floor jack. He does...now this is the clincher......THE FLOOR JACK AT FULL HEIGHT STILL DOESN'T LIFT THE TIRE OFF THE GROUND ENOUGH TO GET IT OFF!!! The more we jacked it up...the more the suspension just dropped down. At this point I'm just laughin'. This poor schmuch has to go back and get this ultra heavy-duty floor jack that they use for semi's and 4x4's. This thing was a monster! It hardley fit under the truck fully compressed! The contact plate looked like a dinner plate! Now I'm really laughin'. This did the trick though. I went to put the jack back in the truck and thought...why the he!! should I? It's useless anyway, might as well save some weight. Anyone else have this experience?
Old Oct 26, 2002 | 07:47 PM
LightningTruck's Avatar
I removed my jack, spare and all that junk. Replaced with a cell phone and AAA number. Saved 70 pounds.
Old Oct 26, 2002 | 07:54 PM
Odin's Wrath's Avatar
Changed mine on the side of the road, with the stock jack, at 4:00 AM on my way to work, in the dark. No troubles, aside from not being able to see very well. You have to use a jack point that doesn't allow the spring to lose tension.
Old Oct 26, 2002 | 07:59 PM
cpeapea's Avatar
hmm
i took my truck to work (discount tire) and rotated the tires with a standard floor jack...worked for me
BLOWN HARD's Avatar
You gotta be smoken something (jp) We've jack our truck us=p on more than one occation... Remember, If all else fails... read the directions.......
Old Oct 26, 2002 | 08:02 PM
Neal's Avatar
Cool
HI!... I've used my stock jack before and had no problems. Don't bother trying to put it at the jack points that are in the owners manual. If I got a flat at the back of the truck I simply put the jack under the rearend center section. If the flat is in the front I used the front cross member.
Old Oct 26, 2002 | 08:28 PM
Rayden's cloud's Avatar
As far as changing a tire the standard jack may work I don't know..What I do know is never try to use that jack when rotating your tires!!! .. If it wasn't for the sender block I placed on the right front Arm my front rotor, bumper would've taken a plunge for the ground...Never try that unless you have a floor jack...
Old Oct 26, 2002 | 08:59 PM
99 SVT Bolt's Avatar
Re: Stock Jack!
Worked ok for me.
Old Oct 26, 2002 | 11:27 PM
MattTx's Avatar
Re: hmm
Which discount tire do you work at?
Old Oct 27, 2002 | 12:52 AM
nitrous63's Avatar
My jack worked fine.....
Old Oct 27, 2002 | 01:18 AM
SpankDog's Avatar
Banned
Hummm i had no problems with my stock jack or a standard floor jack..........
Old Oct 27, 2002 | 05:12 PM
TomG's Avatar
I'm wondering if we all got the same jacks with our trucks. I have a 2000 L and was not able to get the stock jack to work. It wouldn't go high enough to get the tire off the ground. I've changed tires with my floor jack several times though.
Old Oct 27, 2002 | 05:18 PM
LightningTuner's Avatar
Sounds like you had the jack under the frame instead of under a part of the suspension. If you put it under the frame, then you have to lift the truck so high that the suspension fully extends then it will start to lift the wheel. You need to place it under the axle housing for the rear, or under the control arm for the front. Under those points it only takes 1-2" of lift to get the wheel off the ground.
Old Oct 28, 2002 | 12:15 PM
svt_hask's Avatar
Registered User
The jack on my 2001 is worthless, thank god a friend drove by with a real jack. I could have gotten the job done with it but it would have taken forever.
