New Twist on Oil Seperator Mod?
The separator has worked for me since day one. I still have yet to see any oil in the output tube to the blower.
I doesn't disable the PCV System, which will get you in trouble with the Smog ****'s here in CA. They still have unconstatutional roadside checks, complete with IM240 (dyno) testing here.
Originally posted by superfords
Imost of you pull your air intake boot off and see oil and don't like it. nevermind the fact that it doesn't affect performance, you just don't like it .
umm sorry, but this just isnt true. There isnt enough oil in there to create MISTING to lean you out. Some of you are grasping at straws coming up with ways to claim its hurting performance.
I still say the best solution is the one Ford SHOULD have done from day one. And that is to put a baffle (or plate sheild) in the valve cover like any other vehicle has. The bean counters at corporate weren't about to manufacture a taller cover for this to work.That is the right way to solve the problem. Haven't tried it yet but I'm going over to R.E.M. to check out the valve train clearance on one of their disassembled engines.
