NEED HELP!! Truck won't idle
Old Oct 23, 2002 | 11:48 AM
E-LO's Avatar
Angry NEED HELP!! Truck won't idle
This morning was fine and made it to work. Now I leave for lunch and the thing won't stay runnning. It will crank fine and just dies . I have to keep the gas on so it will run and that's how I made it home just now. I just changed the fuel filter about 500 miles ago. I got no check engine light on . What could it be? plugs?
Old Oct 23, 2002 | 12:04 PM
Shorty's Avatar
got any mods? lately? sounds like a fuel pump.
Old Oct 23, 2002 | 12:07 PM
99svtlightning's Avatar
I would guess the hose slipped off your pump. Check to make sure your MAF and intake tubes are plugged in too.
Old Oct 23, 2002 | 12:09 PM
E-LO's Avatar
All I got is an Air Aid
Old Oct 23, 2002 | 12:11 PM
Jeff's Bolt's Avatar
Hey Eddie
call me at work 770 446 8617
Jeff
Old Oct 23, 2002 | 12:17 PM
lurker's Avatar
Sounds like a big vacuum leak to me. Pumps usually cause problems under load, idles are fine.
Old Oct 23, 2002 | 12:41 PM
Silver 2002's Avatar
Is it dying as soon as it starts. If so, sound like mass air to me.
Old Oct 23, 2002 | 12:42 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Idle Air Control (IAC)
Old Oct 23, 2002 | 12:59 PM
E-LO's Avatar
Well, I just got back to work and it ran fine . It just got really cold down here maybe that's it . I will check all these things once I get some time. But shouldn't I get a Check Engine light or something?
Old Oct 23, 2002 | 01:17 PM
ED
Forgot to tell ya GOOD LUCK on your Race!!!!!!!!!!!!!
Jeff
Old Oct 23, 2002 | 01:19 PM
SpankDog's Avatar
Banned
Hummmm, my truck seems to be loving this cold weather. Im thinking about going to the track friday.
Raoul's Avatar
25 Year Member
When my IAC fouled I did not get a check engine light. It did exactly as you described, Start and die. You can check if the IAC is the problem easy enough. Next time the truck won't idle, hit the IAC a few times. If it is the problem, tapping it will unstick it and the truck will idle on it's own.
Old Oct 23, 2002 | 01:55 PM
Rayden's cloud's Avatar
Mines too Spank.
Old Oct 23, 2002 | 03:10 PM
mecca's Avatar
Im TOTALLY loving the cooler weather... Down here FL it never gets cool, but the past couple days it has been. Cool for us (70ish)... there is definitely a HUGE improvement in performance...
-Mike
Old Oct 23, 2002 | 03:14 PM
SpankDog's Avatar
Banned
We are getting pretty lucky here i think. Its been in the 50-low 60s most days and into the 40's at night.
