New Best Time, future mods?
Old Oct 21, 2002 | 10:50 AM
Injector Dude's Avatar
I headed back to the track with the same mods, Chip, 4# Pulley, Accufab T/B and Mac Filter kit. I am still running on the Factory F1's and the truck has about 2600 miles on it.
Previous best was a 8.37@83.3 with a 1.86 60 ft
With the cooler weather I was able to fo a 8.25@84.9 with a 1.88 60ft.
New mods:
REM 6# pulley, REM Chip, NGK TR6 plugs, Nitto Drag Radials, Lakewood Traction bars, and Metco DS Loop.
I am going to try to get these on the truck this week.
Anyone have any idea how much these mods should improve my times?
Old Oct 21, 2002 | 03:17 PM
yysenhimer's Avatar
1.86 60ft on F1's? or 1.86 40 ft time? I don't know how anybody can get 1.86 60ft on F1's. Did you put compound on the tires and heat them up with a blow torch? Was it downhill? Don't mean to be a wise a$$, just curious. Tell us your secrets.
Old Oct 21, 2002 | 03:54 PM
I dont think mine is any secret.....I go around the water box if possible, and do a lite burnout and stage VERY shallow. I do a little longer burnout if I have to go through the water, and I do it off to the side of the groove and drive into the groove rigth before I stage. The other thing is roll into the throttle smoothly. I think the main trick is the last two, stage shallow and roll into the throttle.
The problem I have with racing on the F1's or any radial is trying to be consistant. Firday night, I went a 1.93, a 1.88, and 1.90. I went a 1.92 when the truck was bone stock. The pass I went the 1.86 on the truck went an 8.39. That was the previous time at the track.
Old Oct 21, 2002 | 04:21 PM
navyguy0023's Avatar
Have a 1.86 60ft using the same method pretty much, but I dont shallow stage.
Old Oct 21, 2002 | 05:33 PM
yysenhimer's Avatar
I do pretty much the same thing. May be your L is making less power because of altitude or something or the track is like glue. I found that I got better 60ft when mine was stock. I race at Englishtown NJ where the track conditions are usually good and it is pretty close to sea level. I don't know. I saw another post where the guy said he got a 1.79 60 ft time on F1's. I find that hard to believe. I used to launch a Mustang on slicks and barely get into the 1.7's. I know they are two different animals but I don't know......
Old Oct 21, 2002 | 05:53 PM
What kind of times does yours run?
Old Oct 21, 2002 | 06:13 PM
yysenhimer's Avatar
My best 60ft ever is 2.05. This past Sunday with a 25 mph head wind it ran the best of 12.89 @ 107.8 with a 2.07 60 ft. Going back there wednesday, supposed to be light wind. F1's are a little tired right now. I have to try some other ways of launching. I try to launch about 1000 rpm. Any higher and the tires go up in smoke.
