F/T V.B. and Level Ten shift kit
I would call Greg or post the question on his board. I asked him some time ago about a trans-go kit and at that time he didn't know what was in the kit.
Now I've got this stupid transgo kit laying around; The FT valve body is perfect by itself.
The parts that make up the Level 10 kit, are what Gregg already changes in the FT valve body (using his own pieces of course). So if you installed the Level 10 kit in one of the FT valve bodies, you'd be negating what makes it a FT valve body.
What Sal said.
And in addition to the valve and 3 springs LEVEL 10 gives you, I rebuild the whole valve body, change the lower circuit springs ( I now machine my own 310 valves, also) and I remove some metal from the bulkhead in the shift circuit. It's a much better shift kit, but nothing you get from Level 10 should be added to my accumulator, it's already in there.
G
G
