Pulley Question...
Old Oct 19, 2002 | 10:05 PM
Nasty Wendy's Avatar
Question Pulley Question...
I've read combos that members have that state they are using a 1/2/3# upper pulley in conjunction with a lower pulley 2/4/6#ers. My question is since the upper pulleys are rated to give its advertised boost with the stock lower pulley, how much more boost do they produce when the larger lower pulleys are used? I would think that a 2# upper would yield closer to 3#s when used with a 4# lower and probably 3plus #'s when used with a 6#er. Anyone got any data on this?
Old Oct 19, 2002 | 10:51 PM
Odin's Wrath's Avatar
This will help.
Old Oct 19, 2002 | 10:52 PM
Rob_02Lightning's Avatar
Most claim the pulleys won't give you the amount of boost they sell them as. I don't know if I agree or not. "But" I happen to have a 2lb upper 2.80 "and" a 4lb Lower 8.50. On the upper the MFG has shown many L with 3lb increases. As far as boost, I have plenty, probaly 15-17 at WOT, but more noticable is the instant 10 lbs I have at like 1/4 throttle, as I get into it, it climbs instantly off the scale way past 10, and then continues to climb all the way into the tach area of the dash board. Got to get a picture of that one day
Lower Pulley Sizes
2# ~ 7.90"
3# ~ 8.17"
4# ~ 8.50"
5# ~ 8.75"
6# ~ 9.00"
Upper Pulley Sizes
Stock ~ 2.93
2# ~ 2.80
I have a spread sheet on the hp gains and torque, but it won't show right here. We showed it once somehow, if I can find the old post.
Old Oct 19, 2002 | 11:44 PM
it won't work
Old Oct 20, 2002 | 04:55 AM
OK OK
Ok now I have some data to crunch. I didn't see any formula's that took the circumference of the pulleys into account. That is the tell tale dimension. I'll crunch the numbers and get back to you guys. Maybe I overlooked something as it is 4am. Later and thanks.
Old Oct 20, 2002 | 10:46 AM
JeffsLightning's Avatar
The diameters that are posted are correct. They are measured where the belt rides not the the actual outside diameter of the pulley. There is at least .250 lip on most pulleys...
Old Oct 20, 2002 | 01:48 PM
GN1270's Avatar
AHHHH Wendy...Imagine our Garage if we were married..LOL
Old Oct 20, 2002 | 02:06 PM
droptail's Avatar
adjustable upper
Is your combo for a quick change at the track? How do you like the setup? Slippage?
Old Oct 20, 2002 | 02:39 PM
Silver_2000's Avatar
If you have Excell installed you will see the spreadsheet that does blower RPM here
http://www.svtlightnings.com/svt/how-to/blowerrpm.htm
If not you can dload the spreadsheet and open it in your application...
Doug
Old Oct 20, 2002 | 02:45 PM
Fast Gator's Avatar
Thanks Doug for the link
AND
Thanks Andy for the foot work
Old Oct 20, 2002 | 05:05 PM
Thumbs up
LOL. Thats pretty good!!! It would be the envy of many thats fer sure.
